I have a karaoke machine that plays avi files, it has come with a small program "createmp3&mp4sglist" to add the files to the hard drive which makes a small dat file which I believe is like a playlist but there is no way of adding more than one file at a time , anyone know a way I can do this faster .
The program runs on xp but I think the karaoke machine is Linux
Results 1 to 9 of 9
I don't know, but ill bet not very many people have karaoke machines in this board, so you'll have to be a little more specific
What is the make and model of the karaoke machine?
From your post, I gather that the machine connects to your xp machine in some manner. Am I correct in this assumption? If so, how? usb, ethernet, serial, or does it make a CD/DVD?
What makes you think the machine runs on linux?
... and any other information you might be able to volunteer.
I know disturbed1 does some karaoke because of previous conversation in another thread. You might pm him and ask him to look in this thread and possibly help. He is also a linux user as well.
Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Thanks for the reply ..... well the karaoke machine is a kod-100 which I have no real info on but I believe it runs on linux, I load the avi files using my xp computer on to the machines hard drive using a program called CDG&MP4SGLIST that came with the karaoke machine . It takes the file numbers and renames it and copies it to the HD and when you completed you then press create list and a sglist.dat file is created on the disk and this I think allows the files to be selected fast by the selecting the number of the track . So I have to input all files one by one which will take years ! If you would like me to send you a copy of the progarm to look at let me know.......Cheers
I do a bit of karaoke, but it's just the normal CD+G stuff.
What you have isn't actually a normal karaoke player, since it does not support CD+G files If it did support CD+G (look for the logo) check out cdgtools , google it + linux. For any CD+G discs to work, you have to have a burner that does RAW DAO writing. Not all models do this, not even the newest of new will. Cdrdao will let you know the write modes.
Try to run the program through Wine, or Virtual Box.
Attempt to open the .dat file with a text editor or an hex editor to figure out the format.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Please email me the CDG&MP4SGLIST program to x1745@yahoo.comOriginally Posted by disturbed1
Would anyone has this utility CreateMp3&MP4SGLIST program for KOD-100 Karaoke system
My CD came with the box but has virus in it
Please email me if you have it or send me a link
I have just bought the same system from Singapore - the system gives a lot of trouble - on the home theater system it drives too much of an echo of the mike.
Now we have a problem - none of the AUDIO tracks seems to play behind the karaoke video. The mike works fine, but the system just does not pick up and play the audio file - we are using the original SD card that comes with the song list etc.
THe system freezes every time you touch a button. Sometimes it will not recover and has to be restarted.
THe Company that mufactures these units do not have ay web help, based in CHINA ...
Hi, I need help:
I have KOD 100 karaoke, it work fine until I format the SD card that come with the machine. I put new CDG and kar song, JPG picture, avi video.
In the main menu I pressed 1 for Photo, display "LOADING..." then "No file in this mode", it is the same problem for selection #2 Music, # 3 Video and # 6 Karaoke. While I checked there are photo file (JPG), music file (mp3), and video file (avi and VOB), and karaoke files (CDG and kar) in the SD flash memory. Selection #4 "FILE" working fine, can see the files inside SD memory and can play the mp3 audio only. Selection #5 "SETUP" working, try to reset to "Factory default setting", but the problem still tha same as above.
I thought probably the SD memory has problem, so I bought another SD memory, format with FAT 32 and put some jpg, mp3, cdg, kar, avi and vob files, but it also has the same problem as above.
I think, probably there is file in the original SD memory that is needed by the system for running the software properly.
If anybody has KOD 100 karaoke system please any important file in the SD memory that comes with the system that may be needed by the system (not the video or music files). My email: Sur618@yahoo.com
Or is the any other possibility - Idea why my system does not work properly?
Thanks,
Sur.
Burning avi/mkv/whatever files as a BD-R/RE data disk for my Blu-Ray player
By Braindrain in forum Authoring (Blu-ray)Replies: 6Last Post: 4th Dec 2011, 09:41 -
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 2Last Post: 18th Oct 2008, 17:06 -
combining .VOB files for DVD player disk
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 12th Apr 2008, 06:39 -
AVI capable player not showing all files on data disk
By Seeker47 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 21:07
