I am looking for a good priced upscaling hdmi dvd player mulitregion+dvix.
not really looked into HDMI before but i have a tv on the way,
i cannot afford a blue ray player at the moment so the next best thing is a upscalling dvd player.
i am based on the UK so i will be looking to buy one here.
try this, the region free hack is available in the dvd hacks section on this site.
http://www.amazon.co.uk/Philips-DVP5...6451624&sr=8-1
Do note that while your post did not specifically mention playing Divx in HD, you should be aware that upscaling DVD players will NOT be able to play HD Divx files. Many people here just assume that because they bought an upscaling DVD player that they can then play their 720 or 1080 Divx files and that doesn't happen. The number of true DVD players that can play HD Divx files can be counted on one hand and they are all expensive.
Philips doesn't necessarily make the best players, but their DVD players can typically be put into multi-region mode without too much hassle.
You don't really have to have an upscaling DVD player. If you have a good HDTV it may actually upscale better than a cheapish DVD player. You'll have to test to see, but it certainly is possible. If you are buying a Samsung HDTV then almost certainly the TV will upscale better than a cheap Philips DVD player.
thanks guys,
when i said divx i meant standard divx not HD
Blu Ray Player Vs DVD Player upscaling picture
By mukeshs in forum DVD & Blu-ray PlayersReplies: 10Last Post: 10th Dec 2010, 02:21 -
dvd player hdmi to computer monitor with hdmi
By Kibble in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2008, 12:35 -
NEXT best upscaling DVD player after Oppo DV-983H.....
By i am x in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Mar 2008, 01:09 -
Convert HDMI back to component to preserve upscaling?
By litmus in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Mar 2008, 12:05 -
HD Upscaling DVD player...is it worth it?
By snadge in forum DVB / HDTVReplies: 7Last Post: 29th Aug 2007, 16:01
Statistics
Newest guides
Latest tool updates
New media comments
