VideoHelp.com Forum
    Mediachance had released EditStudio PRO 6.
    What's new:
    Streamlined Interface
    Integrated Multi-Camera editing
    Alpha Transparency on layers and various overlay modes
    Vectorscope/Waveform/RGB Parade (also Live Scopes in capture)
    Navigator View (allows easy access to whole project)
    Color Bar and Tone generators
    Quick Matte to directly paint Transparency Matte on a video with a brush
    Mark In/Out dialog
    Easy access to Toppings from Properties
    Templates for HDV HD1 and HDV HD2
    Audio/Video loops and multiple Loop Markers
    List of included Import/Export plug-ins
    EditStudio 6 is supplied with many high-quality internal import/export plug-ins to overcome the common codecs nightmares, but works also with other DS codecs for added flexibility:
    DV file with smart rendering: Internal Import/Export
    MPEG-1, VCD, MPEG-2, SVCD, DVD, DVD-VR, CableLabs, DVB, MicroMV, DVHS, ATSC, HDV HD1, HDV HD2, D10, XDCAM: Internal Import/Export
    Windows Media 7,8,9: Internal Import/Export
    Quick Time: Import/Export (require QuickTime installed)
    AVI (DIVX, XVID, MJPEG etc..) using available DirectX codecs.
    MP4, H264 AVC Import (require QuickTime 7.3 and ffdshow, read more)
    Frame-Serving to other applications using free Debugmode Frameserver
    EditStudio 5 PRO is different than many other video editing applications in this price range. It is a complete video editing package with standard windows interface, professional quality tools and results. It is a flexible tool that offers all types of standard and advanced video capturing, editing, MPEG2 encoding and Subtitling in one package.
    High Quality MPEG-2 encoding
    Because EditStudio uses one of the most advanced Mpeg-2 encoder, it is a great companion for DVD authors and will let you produce highest quality DVD files.
    The Advanced MPEG settings allows you to tweak every aspect of the encoder - something you can't find in many other encoders or editors.
    Fresh and Clean Video Editing Approach
    You will soon discover one of the EditStudio strongest feature - the unlimited stackable effects and transition layers.
    Instead of applying the effect directly to a video track, you can use the effect tracks instead.
    This makes handling the project much easier and much more visually oriented than in other applications. It is easy to position the effect to the exact frames without splicing the video. It is easy to move the effects or resize them in timeline or even copy and paste them without touching the video tracks!
    And you can even add key-frames to the Effects themselves, allowing for example for smooth transition from one color correction setting to another.
    etc...
    read on:
    http://www.mediachance.com/video/index.html
  2. The package looks interesting however maybe someone can answer a few questions for me.
    1. Is there AC3 support both for exporting and importing.
    2. Does this support 24P from the HV20.
    3. It mentions it uses the best mpeg2 encoder???? (Whats the name?)
    4. Rendering engine, is it background rendering?
  1. Not Sure if the Pro Version will fix this problem.
    By Wakewatcher in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Jan 2011, 12:34
  2. Editstudio Pro 6: Effects problem
    By Sillyname in forum Editing
    Last Post: 14th Aug 2010, 19:59
  3. EditStudio 6 PRO - Video editing
    By devilcoelhodog in forum Subtitle
    Last Post: 24th Oct 2009, 14:21
  4. EditStudio Pro 5
    By Illusionist in forum Newbie / General discussions
    Last Post: 18th Jul 2008, 17:25
  5. EditStudio pro users
    Last Post: 16th Mar 2008, 17:52
