  1. I'm a MEGA Super Moderator Baldrick's Avatar
    Tools required: Paint Shop Pro.
    1. Write your how to/guide with a text editor like Word,Notepad or something. Or you can use a html editor to make it with tables and stuff.
    2.Make screenshots but remember you must keep down the size, the max file size for each image is 50 KB (= 51200 Bytes). Use for example Paint Shop Pro and use it own capture utility, configure it under File->Import->Screen Capture->Setup and select capture Window.
    Export to png or gif or jpg and reduce to colors to about 64 and you can keep down
    the size, File->Export->Png Optimizer.
    Note! Max 50 KB (= 51200 Bytes) for each image.
    3. In your textfile add
    [/img]
    where you want your screenshots (you can use png,jpg and gif images but max 50 KB).
    4. Click on the new topic in the user guides forum and copy and paste the text into the message body and choose a good Subject.
    5. Add the images by selecting them under UPLOAD IMAGES, if you have more than 5 images you add them later by clicking on edit button on your guide.
    Note! Max 50 KB for each image and the image filenames must be in lower case!.
    6. Submit the guide. You can easily edit and add more images by clicking on the edit button on your guide.
    Note If you preview the guide YOU wont see any images. Post the guide and if something is wrong just click on the edit button to fix it.
    Remember that you probably will get some both bad and good feedback about your guide...but you can always update your guide or if you dont like it remove it.
    We will also link to your guide in the main How To sections and on the main vcdhelp page and it will then look something like this
    http://www.vcdhelp.com/forum/userguides/92056.php
    http://www.vcdhelp.com/ or http://www.vcdhelp.com/latesthowtos.php
    If you don't want people to reply directly in your guide I can make the topic closed. Just email or private msg me then.
    Hi Baldrick,
    will it be possible to use Flash in the message body?
    Some screencapture software use Flash, and it's very useful to demo like this, especially when sound is involved.
  3. Member KneeGrow's Avatar
    Me thinks Flash would exceed the 50 k limit ... How about all our dial up friends? in Northern Finland .... Central Australia .... Upper Tasmania ? :P
    River Tam: "Can't look, can't look!
    wrong post
    I've made a guide in MS Word. I want to post it here but the problem is, the images were not imported into word. Meaning I screenshots them using the Print Screen key on my keyboard and then pasted it directly into the word document. In this case, how do I go about posting the guide?
  1. Since Dobly Digital is Possible is there a guide to make it?
    By gotenks98 in forum Newbie / General discussions
    Last Post: 21st Mar 2004, 11:18
  2. Could someone make Guide about how to replace subtitles...
    By egonrEST in forum Newbie / General discussions
    Last Post: 27th Nov 2003, 21:32
  3. can someone make a guide to Procoder? the software?
    By wizzy in forum Newbie / General discussions
    Last Post: 15th Sep 2002, 09:32
  4. Can webmaster make a guide...
    By dj_magic in forum Authoring (VCD/SVCD)
    Last Post: 26th Apr 2002, 12:02
  5. Here is a Guide on how to make XSVCD
    By Zeven in forum Video Conversion
    Last Post: 12th Mar 2002, 15:19
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
