This may be a rookie question but I really need an answer here~~
I have HD cablebox~~recently I've tried to connect cable box to my computer~~but I couldn't find a connector that fits both equipment~~my cable box has component video out(RGB)~~DVI-D~~RF coaxial~~and analog tv out~~and my TV Card has analog cable tv in~~s-video~~ATSC/QAM digital tv in~~and stereo audio in~~~i could connect both with analog cable~~but it will sacrifice picture quelity~~I'm wondering is there anyway that I can connect my cable box to the ATSC TV port on my TV card~~? Do I need a converter to do that~~?
Also~~can I connect my monitor to the cable box through DVI-D cable~~?
Thank you guys~~any help will be appreciated~~
Your monitor should be fine.
Your probably not going to be able to connect a cable box to a pc....I believe the boxes are encrypted so that data cannot easily be taken from them...Someone else may have more knowledge, but as far as I know there is no work around.
No. But you can connect the video capture card directly to the cable coax feed (split the feed before it goes to the cable box). You will be able to tune the analog channels and any unencrypted QAM channels (mostly limited to your local OTA broadcast stations). You will not get any encrypted content.Originally Posted by bl3311
To capture encrypted high def channels you will need something like a Blackmagic Intensity Pro card. Then you can capture via the cable box's component output.
Connect LCD monitor to Digital HD Cable box?
By rogerconnery in forum DVB / HDTVReplies: 84Last Post: 18th Jan 2012, 06:04 -
How would I connect my standard cable box to my HD LCD monitor?
By Jadedrain_06 in forum Video ConversionReplies: 4Last Post: 27th Nov 2011, 12:00 -
Anyone ever connect their cable box to a projector?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 13:53 -
HELP! Connecting cable box to computer for HD Recording
By wickedwheels in forum DVB / HDTVReplies: 16Last Post: 29th Aug 2009, 21:25 -
How to connect a monitor to a digitanl cable box?
By Latvian in forum DVB / HDTVReplies: 3Last Post: 3rd Dec 2008, 00:47
Statistics
Newest guides
Latest tool updates
New media comments
