I have a Pioneer DVR-520H. It recently stopped finalizing discs. I usually use DvD-RW to transfer content to my PC for editing anyway, and NeroVision extracts the files without finalizing, so that's not the problem.
But, more so than not, I can only fill 20-30% of the disc. The transfer, according to Nero and even IsoBuster gets corrupted. The portions that I do recover are fine, even though some are missing video at the end. Re-burn, re-burn, re-burn and I get my video. Editting does the rest.
Even though I do end up recovering all my video it's getting painful doing this almost file-by-file.
Repair places have been useless. They tried a firmware upgrade that (sort of) worked for a month or so, but again the same problem. Replacing the burner part is not an option since it would cost more than the unit itself.
Any advice from someone knowledgeable or someone who's solved this? Anything I can download and try?
Or should I just bite the bullet, accept its demise and get another one... this post is a last hope, just in case.
Thank you for reading.
Thread: Pioneer DVR-520H Can't finalize.
Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Well, Lo and Behold! Problem solved.
Since nobody was able to help, I will update this thread for the sake of completion and in case someone else needs similar help and their search leads here.
I bought a disc cleaner from Maxell - a disc with a brush attached - and it solved the problem! Wow!
I always thought these things were bullspit, but not this one, and I will say a nice word for the company just for that. (I even called to thank them.) So it was just a dirty lens problem all along... sorry to trouble the forum with this, but hopefully it helps someone else.
Everything works fine now. Problem solved!
I also thank FulciLives for his post here, which has some valuable info on this subject.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Sounds like you might want to find a DVR-107 just in case. The disc cleaner will work for awhile.Originally Posted by PuzZLeR
I have a line on some replacement drives. See this link, http://forum.videohelp.com/topic303341.html
NEW.
PsyMaster4 XP Pro Systems, 1 FreeBSD 7.0 system, Pioneer DVR-520H, Pioneer DVR-225, Phillips DVR-3567H, Teac replacement drives for DVR-107xa
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 08:24 -
PIONEER DVR-520H-S
By K_cin_az in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Jun 2011, 02:18 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Pioneer DVR 520H and HDTV
By WCM in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Feb 2008, 13:38
Statistics
Newest guides
Latest tool updates
New media comments
