VideoHelp.com Forum
Results 1 to 21 of 21
    hi...
    i want to convert vcd(.dat) file to avi..but wen i open file in virtual dub i get this pop up n the entire vide isnt gettin converted only the part which video stream is chck is bein converted n remainin is not.....so plzzz help me outtt........plzzzzzz
  2. Mod Neophyte Super Moderator redwudz's Avatar
    The warning fairly well summed it up, the file may be damaged or incomplete. You can try opening it with 'File>Open video file' then at the bottom left of the page, select, 'Ask for extended options after this dialog', then the next page 'Redirive keyframes'. This can fix the index most times, but you may have more problems.
    And welcome to our forums.
    Try using vcdgear to first grab the mpeg from dat, then try vdub again
    Personally, its vcdgear, then avidemux for such things
    thnx fr rplyin bt i didnt get u.....wer can i find this extended option
    actually its a dat file..then wats d use of goin 2 vcdgear n 1 morethin the video isnt corrupted i mean i can play d whole movie perfectly without any probs....................so plzz help me out guyss........i want 2 convert this moviee plzzzzzzzz
  6. Mod Neophyte Super Moderator redwudz's Avatar
    I've never had any problems opening VCD .dat files with VirtualDub. I use VirtualDub Mod most times, but the newest VDub should work also, but you may need to add the MPEG plugin for it. I find VD Mod a lot easier to use.
    Just because a file plays back doesn't mean it can't have errors that can interfere with copying it. Players can ignore some errors that a encoder program will choke on.
    For VDM:
    But that may not help any with the program not being able to load the whole file.
    different when importing MPEG files:
    Using the latest DirectShow source filter from the link below might work.
    http://forum.videohelp.com/topic348265.html
    I have a DAT file with the same problem. Using the DirectShow source filter allowed conversion of the entire file.
    can you play the whole movie on the PC? with which player?
    windows media player..n thnx guys bt i tried wit virtualdubmod bt its nt workin.....
    in that case, loading via directshowsource in virtualdubmod should work
    you will need to install avisynth for it to work.
    i installed avisynth n copyd DirectShow source filter in plugin folder of virtualdubmod n wen i use DirectShowSource in AviSynth template..im gettin popup sayin "Failed to Create Script"
    mgh plzzzz hekp me man........
    the directshowsource filter should be in the avisynth plugins folder. which version of avisynth have you installed?
    edit ps
    btw the directshowsource plugin mentioned in the post above is for the latest versions of virtualdub and not virtualdubmod. it should ideally be installed in the plugins32 folder of virtualdub (1.7.7 or later). might work as well since it is based on the avisynth directshowsource filter.
    You seem to be ignoring some good advice. To summarize:
    1) OK playback does NOT always mean the file is fine.
    2) VCDgear has a tool for fixing minor problems. Use the .dat --> .mpg conversion option with "fix mpeg errors" checked.
    3) Hope for success.
    well mgh i did as u said b thers no use........i used avisynth 2.5 n virtualdub 1.7.7 i copied directshow plugin in avisynth plugin folder bt thers no use im gettin d same probs..........well im gettin other .dat videos bt this video is only troubling me...........
    avisynth+virtualdubmod as i have shown-should work if the file is playing in windows media player correctly
    or
    virtualdub 1.7.7 with the directshow source plugin mentioned in
    in its plugins32 folder-while opening file select the file first then select directshowsource from the file type dropdown list and click OK-might also work as the plugin is based on the avisynth directshowsource filter.
    you are mixing up the wrong things together
    Another thing to note is that virtualdub is complaining about timecode breaks. You've gotten a lot of good suggestions, but if those don't work, you may wish to give MPEGstreamclip (free and great) a try. It has the ability to fix such breaks. It may not be able to do so directly on .dat streams (but maybe it can), so you may have to use vcdgear to perform a .dat --> .mpg conversion, and then use MPEGstreamclip to fix timecode breaks.
  17. Member AlanHK's Avatar
    VCDGear has an option to "fix MPEG errors" when making its MPEG. That may be enough.
    Anyway, a DAT (like a VOB) sometimes works as an MPEG, but better to make a proper MPEG.
  18. Member
    Yup, that's exactly why I already mentioned the "fix MPEG errors" feature in my first post. The second post was to provide additional suggestions in case the earlier ones don't work for some reason or other. My suggestion there to use VCDgear to convert from dat to a true mpeg was precisely to address the point that you raise.
  19. Member AlanHK's Avatar
    Sorry, I skipped over the earlier posts.
    And the OP appears to be paying even less attention.
    That does seem to be the case!
    k..thnx fr givin replies guys.......i lost my net so i didnt giv any response.srry mgh i wil try n tell if im gettin r nt....thnxx again fr rplyin
  1. VCD 2.0 help me plzzz
    By khankadir in forum Authoring (VCD/SVCD)
    Last Post: 14th Nov 2011, 12:38
  2. Corrupt File Needs Fixing, PLZZZ
    By kame1986 in forum Newbie / General discussions
    Last Post: 6th Apr 2011, 02:51
  3. noob-help! plzzz! video-ts folder files export to something i can use...
    By shedev in forum Newbie / General discussions
    Last Post: 24th Mar 2010, 13:27
  4. I have converted avi to vcd and svcd im looking to convert avi to dvd
    By dbztoolkit in forum Newbie / General discussions
    Last Post: 11th Jun 2007, 12:14
  5. Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
    By scratchman in forum User guides
    Last Post: 4th Jun 2007, 01:36
