with my BlackMagic Intensity Pro.
I have it installed. But I can not get anything to display when I open my capture software.
How do I hook it up?
I'm trying to capture from PS2, Xbox, PS3, and Xbox 360.
I have tried using the HDMI from the card to my TV, that doesn't show anything on the computer. I have hooked up my PS3 component cables to the cable that came with it, nothing. I have hooked up component cables from the card to the tv, nothing displayed.
Thread: Capturing from Intensity Pro
Do you have the correct input selected in the Intensity Control Panel?
I assume you mean in the media express capture sfotware that comes with it. I have tried every combination. I also have used Pinnacle 11 and Sony Vegas 8 with all possible combinations and can't get a display.
If someone could simply tell me how to hook it up and with what settings, that would be great.
Another issues I'm having is now I have no sound and when the Intensity card is in my PC, it occasionally locks everything up. I currently have the hardware removed because of this issue.
Are you connecting the PS3 to the card using HDMI?I ask because i have heard that the card will not work with the PS3 with HDMI but will usingcomponent so since you have the pro try and use the component instead.Originally Posted by KameronK
Intensity Pro - Capturing Stills
By khargy in forum CapturingReplies: 11Last Post: 15th Apr 2012, 02:13 -
BlackMagic Intensity Pro And PC Capturing
By MattyXz in forum CapturingReplies: 0Last Post: 29th Feb 2012, 19:29 -
PC to PC capturing with Intensity Pro
By luc2010 in forum CapturingReplies: 16Last Post: 29th Nov 2010, 20:02 -
Capturing Gameplay with Intensity Pro
By Jz1991 in forum CapturingReplies: 3Last Post: 18th Feb 2010, 08:09 -
Capturing using Intensity Pro
By teknix1 in forum CapturingReplies: 10Last Post: 29th Jan 2010, 09:02
Statistics
Newest guides
Latest tool updates
New media comments
