VideoHelp.com Forum
    I tried a forum search but didn't find an answer to my specific question. If my asset is a .TS file from a HDTV program, and it's not long enough (55 minutes) to require an Autofit, is there still a benefit from using 2-pass encoding? Thanks!
    P.S. I really enjoy this program and am really glad I registered!
  2. That's really a question that can only be answered by your own eyes. That being said, I have been very pleased with one pass mode on even longer sources.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Thanks for the respone! But I'm basically trying to understand the process of 2-pass encoding. From what I've gathered through my searches, a short asset that doesn't require Autofit will be encoded at the highest possible quality within the DVD spec which is 9000kbs. And, unless I've misunderstood, 2-pass encoding will normally end up adjusting the bitrate so that it's higher on scenes that need it (a lot of movement, for example) and lower on calmer scenes. But if a short asset is encoded at the maximum bitrate of 9000kbs throughout, does that mean that 2-pass encoding will have no effect on it, or am I misunderstanding the process?
  4. Member ChrissyBoy's Avatar
    That is pretty much spot on. Only if you are down below the max would you see any benefit - for the reasons you cite.
    Thanks for clearing that up. And thanks for a great piece of software!
    I am having trouble with two pass encoding on a .ts (hdtv) program that is of any length. I get the memory error problem that others have posted. After searching this forum I have found that using two-pass encoding is causing the problem and that I should only use one-pass encoding.
    I have the latest version and wondering what is the word on this problem, if any? Should the two-pass encoding work? Why is the option available if it shouldn't be used?
    Thanks for any updates on this issue.
  1. Replies: 8
    Last Post: 21st Sep 2011, 21:11
  2. Difference Between 1 pass & 2 pass encoding
    By iqbal88 in forum Video Conversion
    Last Post: 9th Sep 2011, 11:52
  3. Replies: 4
    Last Post: 26th Nov 2009, 05:46
  4. 2-pass encoding?
    By andyx181x in forum DVD Ripping
    Last Post: 23rd Feb 2008, 00:16
  5. SVCD2DVD 2.5 One Pass vs. Two Pass encoding?
    By mwkurt in forum SVCD2DVD & VOB2MPG
    Last Post: 19th Jun 2007, 14:55
