Basically what I want to do is compare the results I'm getting with 4 different codecs. I have a single avi file I'm starting with. I want to divide the screen into four parts and simultaneously display a small, magnified portion of the video as produced by each of the 4 codecs.
I know how to crop the video with Vegas, but I don't know how to move the cropped image to the corner of my choice. It just stays where it originally was on the screen.
Any help would be greatly appreciated. Even key words or phrases I could lookup. Since I don't know what to call what I'm trying to do, finding results has been difficult.
Results 1 to 11 of 11
better to render each codec at the same size then take the exact frame into your photo program, enlarge, then look for fine print
it will become clear that each piece of video is different and uniqueAuthor, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
You can do this sort of thing with avisynth. Playing 4 different clips at the same time like "picture in picture"
Here's a tutorial, unfortunately some of the screenshots are dead. If you scroll down you can see some youtube samples
http://www.gtplanet.net/forum/showthread.php?t=69316
a = AVISource("clip1")
b = AVISource("clip2")
c = AVISource("clip3")
d = AVISource("clip4")
e=StackHorizontal(a,b)
f=StackHorizontal(c,d)
StackVertical(e,f)
Or you could try embedding them into an HTML file and auto-starting all of them at once.
I don't know if that can even be done, but it seems to me that it "could" possibly be do-able.
Can anyone educate me on this?Even a broken clock is right twice a day.
Avisynth is a lot easier and doesn't tie you to the few codecs that can be easily served from HTML. Creating a webpage for a simple comparison is just too silly for words.
In another forum I was given the answer.
"Pan/Crop will let you select a small portion of each video, as you've already discovered. Track Motion will let you position those portions where you want them in the frame."
Thanks for your suggestions. I hope this solution helps anyone else having the same difficulty.
Hello guns1iger
With reference to another thread, I have tried this method and created the following script to compare all the three files side by side:
As I try to open the AVS file in VirtualDub I get the following error:Code:a = AVISource("K:\Movies\Fistful of Dollars\Fistful of Dollars (AGK).avi") b = AVISource("K:\Movies\Fistful of Dollars\Fistful of Dollars CQ crf 18.mp4") c = AVISource("K:\Movies\Fistful of Dollars\Fistful of Dollars HQ Fast profile.mp4") StackHorizontal(a,b,c)
Now, the .mp4 file, related to which VD is giving error can be opened normally in VD without any problem (for example when I just drag and drop the file in VD window).
Please check the AviSynth file and let me know where I made the mistake...
আমি বাংলায় গান গাই
Try using DirectShowSource instead of AVISource for your mp4 files.
Thanks,
changing to DirectShowSource worked, but I can see only one movie window in VD, am I not supposed to see two side by side?
আমি বাংলায় গান গাই
Sony Vegas 9: Any way to record through multiple mics?
By duderdude2 in forum EditingReplies: 5Last Post: 17th Mar 2010, 22:50 -
[Sony Vegas] editing custom codec'ed videos
By Louie413 in forum EditingReplies: 4Last Post: 20th Feb 2010, 11:39 -
Sony Vegas renders my recorded videos badly.
By Daikun in forum EditingReplies: 9Last Post: 24th Oct 2009, 09:37 -
Sony Vegas 8 Pro Question - How to crop entire movie with multiple videos?
By Mysteriouskk in forum Newbie / General discussionsReplies: 4Last Post: 5th Mar 2008, 19:50 -
Sony Vegas -- Issues With Videos
By wrathofnero in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2007, 21:55
