Hi Pals,
really newbie to this area
have read thru numerous posts but still unsure which cable i need
I have this graphics card nVidia Geforce 7300 GS
and this LCD TV : Samsung LA32R71BAX
Input & Output(Side) HDMI No
composite (AV) 1
S-Video 1
Headphone 1
Input & Output(Back) HDMI 2
composite (AV) 1
S-Video No
PC input (D-sub) 1
Component(Y/Pb/Pr) 2
please advise on which cable/conn should i get to get the best display
Thank you all !
With the TV as the only display? DVI to HDMI cable. Like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812203029
Or with a DVI to RGA adapter and VGA cable:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812226014
http://www.newegg.com/Product/Product.aspx?Item=N82E16812108106
Your card may have come with the adapter.
The latter may be the better choice because the TV will probably not overscan the VGA input. -
The only officially supported PC input on my Samsung LCD (different model from the original poster) is VGA. I think it is theoretically possible to connect a PC to Samsung LCDs via HDMI or DVI, but you have to be careful about the refresh rate as all are not supported. The TV manual might be helpful.
As far as I know all Samsung LCDs overscan via HDMI, DVI and component connections. Certain models may have firmware that defeats overscan only on the HDMI input. Samsung doesn't like customers to do their own firmware upgrades, so they don't typically make the firmware available. Some have reported ruining their TVs when trying to do their own firmware upgrades, so I don't recommend it. If the original poster doesn't want overscanning, a VGA connection is best. -
Originally Posted by jman98
That is a 1366x768 TV.
You can drive it with VGA at 1366x768 @60Hz. This is the easy solution.
For DVI->HDMI check the manual to see if 1366x768 with "just scan" is supported. Without "just scan", the TV will overscan.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
On my LNT-4665 if I change the input name to "PC" it will not overscan when set at 16:9. I don't know if the 720p sets do the same.
Thank you all for the suggestions
went out to buy a DVI to VGA cable
seems my graphics card has s-video and DVI outputs
Connect computer to LCD TV?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2010, 18:08 -
HP p6380t connect to Sharp LCD help
By MateenCleaves in forum ComputerReplies: 0Last Post: 18th Feb 2010, 17:00 -
Connect LCD PC Monitor to DVD Player
By tsloby in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2009, 11:01 -
How do I connect my laptop to my LCD TV?
By Nenra in forum Newbie / General discussionsReplies: 9Last Post: 30th Jan 2008, 15:06 -
best way to connect new LCD Tv to computer
By slackbladder in forum DVB / IPTVReplies: 9Last Post: 14th Nov 2007, 15:53
