I'm trying to put four episodes of a show on 1 disc, and they keep being put on the disc as 4,3,2,1 instead of 1,2,3,4.
They are named
JS 01
JS 02
JS 03
JS 04
I've never has a problem doing multiple shows before. Any hints?
Thanks!
Try A, B, C, D. Windows counts different.
huh, I'd have never thought of that.
thanks
No joy, folks. Any other ideas?
When you use windows it does funny things to file order
If you were to highlight 4 files named
1
2
3
4
and add them to something they would add as
2
3
4
1
to avoid that you would highlight 2,3, & 4 then hold down the Ctrl key and click on 1. Doing that would add them in the proper order. Many, many programs use windows file services as it is much easier than writting your own routines.
I'd be willing to bet that is what is really happening to you. Give it a try
Allllllllllllllllllllllllllllllllllllllrighty, I'll give it a shot.
If you are using winavi use the arrows on the left to move the files up and down to what ever order you want them.
NeroVision: DVD menu chapters highlight in wrong order
By Grunberg in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2011, 18:35 -
bizarre bug - DVD tracks playing in wrong order in DVP5990/92
By lhughes in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Aug 2010, 04:23 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
What am I doing wrong with WinAVi?
By alex0000 in forum Video ConversionReplies: 1Last Post: 7th Feb 2010, 07:27 -
Can I put multiple video files onto one DVD?
By flameout in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 15:12
