Techarp is hosting a new HD x264 benchmark. Have a look and run it on your system to help populate the data table.
Basically, you run the test encode of an HD sample (1280x720) and it will report back frames-per-second values for your machine @ it's clock/overclock level. You can run it at your stock settings and at your overclock settings to see how your machine compares to others in the database.
My goal is to have a representative set of data for many different chips and chipsets. Please just report your results here in this thread. I will keep the data at that url to keep things simple.
Thanks all and enjoy!
The following image will be updated automatically as new data comes in. It doesn't display any results, but it does show the number of data points collected so far and how they break down by CPU type:
Results 1 to 30 of 109
http://encoding.n3.net <-- for all your DVD and CD backup needs!
Intel Mobile Core 2 Duo T7200
6.0 x 166.2 MHz
DDR2 5-5-5-12 @ 333
Intel i945GM rev. 03
Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
---------- RUN1PASS1.LOG
encoded 1442 frames, 21.13 fps, 3905.08 kb/s
---------- RUN2PASS1.LOG
encoded 1442 frames, 20.28 fps, 3905.08 kb/s
---------- RUN3PASS1.LOG
encoded 1442 frames, 19.66 fps, 3905.08 kb/s
---------- RUN4PASS1.LOG
encoded 1442 frames, 19.55 fps, 3905.08 kb/s
---------- RUN1PASS2.LOG
encoded 1442 frames, 5.17 fps, 3942.92 kb/s
---------- RUN2PASS2.LOG
encoded 1442 frames, 5.07 fps, 3942.92 kb/s
---------- RUN3PASS2.LOG
encoded 1442 frames, 4.91 fps, 3942.92 kb/s
---------- RUN4PASS2.LOG
encoded 1442 frames, 4.86 fps, 3942.92 kb/s
Thanks as always, Baldrick!
intel core 2 quad 6600
kentsfield
9x256.1
ddr2 3-4-4-10 2t @256.1
via pt880pro chipset
ms winXP sp2
encoded 1442 frames, 46.14 fps, 3905.42 kb/s
encoded 1442 frames, 46.47 fps, 3905.42 kb/s
encoded 1442 frames, 46.63 fps, 3905.42 kb/s
encoded 1442 frames, 46.12 fps, 3905.42 kb/s
encoded 1442 frames, 13.03 fps, 3952.85 kb/s
encoded 1442 frames, 13.01 fps, 3952.85 kb/s
encoded 1442 frames, 12.97 fps, 3952.85 kb/s
encoded 1442 frames, 12.97 fps, 3952.85 kb/s--
AMD ATHLON 64 X2 4800+
TOLEDO
12.0X200.9
DDR 2.5-3-3-8 2T @134.0MHZ
NVIDIA NF-CK804
MS WIN XP HOME SP2
encoded 1442 frames, 23.05 fps, 3905.08 kb/s
encoded 1442 frames, 23.02 fps, 3905.08 kb/s
encoded 1442 frames, 23.16 fps, 3905.08 kb/s
encoded 1442 frames, 23.11 fps, 3905.08 kb/s
encoded 1442 frames, 5.63 fps, 3942.92 kb/s
encoded 1442 frames, 5.62 fps, 3942.92 kb/s
encoded 1442 frames, 5.65 fps, 3942.92 kb/s
Cool, thanks for the data guys!
AMD Athlon 64 X2 3800+
Manchester
10x240
DDR 2-2-2-5 2T @ 200mhz
nVidia nForce4
Vista Ultimate 32-bit
encoded 1442 frames, 23.41 fps, 3905.08 kb/s
encoded 1442 frames, 23.37 fps, 3905.08 kb/s
encoded 1442 frames, 23.39 fps, 3905.08 kb/s
encoded 1442 frames, 5.56 fps, 3942.92 kb/s
encoded 1442 frames, 5.46 fps, 3942.92 kb/s
encoded 1442 frames, 5.47 fps, 3942.92 kb/s
Thanks bmo, added.
AMD Phenom 9500 Agena
11 X 225Mhz (Overclocked 25Mhz to 2477Mhz)
DDR2 5-5-5-18 @ 450Mhz (DDR1066)
AMD ID9600 Chipset
Vista Home Premium 32Bit
encoded 1442 frames, 51.33 fps, 3905.42 kb/s
encoded 1442 frames, 50.90 fps, 3905.42 kb/s
encoded 1442 frames, 50.84 fps, 3905.42 kb/s
encoded 1442 frames, 51.10 fps, 3905.42 kb/s
encoded 1442 frames, 12.59 fps, 3952.85 kb/s
encoded 1442 frames, 12.67 fps, 3952.85 kb/s
encoded 1442 frames, 12.66 fps, 3952.85 kb/s
encoded 1442 frames, 12.71 fps, 3952.85 kb/s
This is a new Gigabyte MA78GM-S2H AM2+ motherboard and I am still optimizing the settings.
EDIT: Here's a overclock to 2.6Ghz
11 X 236Mhz (Overclocked 36Mhz to 2602Mhz)
DDR2 5-5-5-18 @ 473Mhz (DDR1066)
AMD ID9600 Chipset
encoded 1442 frames, 56.26 fps, 3904.67 kb/s
encoded 1442 frames, 56.12 fps, 3904.67 kb/s
encoded 1442 frames, 56.02 fps, 3904.67 kb/s
encoded 1442 frames, 56.05 fps, 3904.67 kb/s
encoded 1442 frames, 13.77 fps, 3952.97 kb/s
encoded 1442 frames, 13.78 fps, 3952.97 kb/s
encoded 1442 frames, 13.80 fps, 3952.97 kb/s
CPU idle=27C CPU max=44C
TLB errata patch disabled.
Killer man, tough to find AMD folks these days. Thanks!
Greetings, here are my results.
P4 D805 (stock speeds)
2.6Ghz 20x133MHz
FSB 533MHz (Mem and CPU)
4-4-4-10
nForce4 680i mobo
Win XP 32
encoded 1442 frames, 14.96 fps, 3905.08 kb/s
encoded 1442 frames, 15.08 fps, 3905.08 kb/s
encoded 1442 frames, 15.10 fps, 3905.08 kb/s
encoded 1442 frames, 15.11 fps, 3905.08 kb/s
encoded 1442 frames, 3.76 fps, 3942.92 kb/s
encoded 1442 frames, 3.75 fps, 3942.92 kb/s
Same P4 D805 OC'ed to 4GHz (watercooled)
20x200
FSB 800MHz (Mem and CPU)
encoded 1442 frames, 17.08 fps, 3905.08 kb/s
encoded 1442 frames, 15.47 fps, 3905.08 kb/s
encoded 1442 frames, 15.24 fps, 3905.08 kb/s
encoded 1442 frames, 15.16 fps, 3905.09 kb/s
encoded 1442 frames, 3.98 fps, 3942.92 kb/s
encoded 1442 frames, 3.87 fps, 3942.92 kb/s
encoded 1442 frames, 3.84 fps, 3942.92 kb/s
encoded 1442 frames, 3.81 fps, 3942.92 kb/s
AMD 3500 2.2GHz 11x200
KN8 nForce mobo nForce 4
2.5-4-4-7
Win XP 32
encoded 1442 frames, 10.66 fps, 3902.58 kb/s
encoded 1442 frames, 11.51 fps, 3902.58 kb/s
encoded 1442 frames, 11.52 fps, 3902.58 kb/s
encoded 1442 frames, 2.64 fps, 3936.11 kb/s
encoded 1442 frames, 2.63 fps, 3936.11 kb/s
Seems I have the wimpy rigs compared to those above me, haha. I'm a bit surprised to see the extra 1.4GHz on my overclocked D805 did not yield a larger difference. Glad to see the info on the Q6600 because that is what I was thinking my next OC'able upgrade might be.
Cheers,
Rick
rick - just don't get a motherboard with a via pt880pro chipset. it won't oc for crap. anything over a 10% oc won't post. i'm going to switch to a p35 chipset board next week.
Get a GIGABYTE P35 mobo for your Core 2 Quad cpu.Originally Posted by aedipuss
@RickA - Thanks for taking the time to bench those systems! First off, I've seen how the Pentium D's overclock doesn't scale before and I can't explain it either
A few questions so I can add your results:
Does the Pentium D system use DDR, SDRAM, or DDR2 memory?
What codename does your Athlon X2 3500+ have? There are three possibilities
CPU-Z should tell you which one you have. Also, what speed is the memory on that system, and is it DDR or DDR2?
Thanks man!http://encoding.n3.net <-- for all your DVD and CD backup needs!
AMD Athlon 64 X2 5600+ Windsor
14 X 200Mhz (No overclock)
ATI RS690/RS690M Chipset
DDR2 5-5-5-18 (2GB DDR800)
encoded 1442 frames, 29.17 fps, 3905.08 kb/s
encoded 1442 frames, 29.24 fps, 3905.08 kb/s
encoded 1442 frames, 28.99 fps, 3905.08 kb/s
encoded 1442 frames, 27.18 fps, 3905.08 kb/s
encoded 1442 frames, 6.80 fps, 3942.92 kb/s
encoded 1442 frames, 6.79 fps, 3942.92 kb/s
encoded 1442 frames, 6.78 fps, 3942.92 kb/s
Thanks redwudz - what speed does your RAM run at (CPUZ can show you on the memory tab)... I'm guessing it's 400 MHz?
AMD BE-5000 14x200MHz
ASUS M2N32-SLI Deluxe
SUPER TALENT 2x 1GB DDR2 5-5-5-15
WESTERN DIGITAL 2x 500GB
COOLER MASTER case
THERMALTAKE fans
Xp Pro hosting 40-some processes
cool & quiet
encoded 1442 frames, 28.76 fps, 3905.08 kb/s
encoded 1442 frames, 28.94 fps, 3905.08 kb/s
encoded 1442 frames, 29.01 fps, 3905.08 kb/s
encoded 1442 frames, 6.56 fps, 3942.92 kb/s
encoded 1442 frames, 6.64 fps, 3942.92 kb/s
Just for this test, I moved AviSynth for the batch if exist "%PROGRAMFILES%\AviSynth 2.5"...!
Thanks for the data, luigi - will update the table shortly.
Thanks all for your input, greatly appreciated. I'm sporting a BFG 680i SLI mobo with the P4 D805 and finding it the friendliest OC board I have used yet. It is also the first one (and rig) that I seriously looked in to with OC'ing in mind. Still much to learn.
If you have more OC advice (prefered CPU's, mobo's, etc) I would like to hear it, please feel free to PM.
Graysky - my apologies, I ment to post the extra info you asked for. The D805 has DDR2. The AMD has DDR and is not overclocked, codename Venice, memspeed 200MHz 1:1 FSB
RAM. It is not an X2 (dual core-?), just a normal Athlon 64. My P4 is the only dual core I have. If there is any way I can help out more with the testing please say.
Here is another test run with the D805 with FSB at 533MHz (2.6GHz stock) and Mem (PC2-6400)
at 800 MHz. Not much of a change between the 533MHz mem clock.
encoded 1442 frames, 15.03 fps, 3905.08 kb/s
encoded 1442 frames, 15.00 fps, 3905.08 kb/s
encoded 1442 frames, 14.97 fps, 3905.08 kb/s
encoded 1442 frames, 15.05 fps, 3905.08 kb/s
encoded 1442 frames, 3.73 fps, 3942.92 kb/s
Cheers,
Rick
Cool, thanks for the update. Tables are now current.
8 Core Mac Pro
Each Proc (x2) - there's 2 physical processors=
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Xeon X5365
Codename Clovertown
Specification Intel(R) Xeon(R) CPU X5365 @ 3.00GHz
Package Socket 771 LGA (platform ID = 6h)
Core Speed 1995.1 MHz (6.0 x 332.5 MHz)
Rated Bus speed 1330.0 MHz
Stock frequency 3000 MHz
Memory Type FB-DDR2
Memory Size 4096 MBytes
Memory Frequency 332.5 MHz (1:1)
Timings table
Frequency (MHz) 333
CAS# 5.0
RAS# to CAS# delay 5
RAS# Precharge 5
TRAS 15
TRC 20
XPPro- 64SP1
encoded 1442 frames, 62.06 fps, 3904.94 kb/s
encoded 1442 frames, 61.77 fps, 3904.94 kb/s
encoded 1442 frames, 61.57 fps, 3904.94 kb/s
encoded 1442 frames, 61.90 fps, 3904.94 kb/s
encoded 1442 frames, 31.95 fps, 3974.08 kb/s
encoded 1442 frames, 31.87 fps, 3974.08 kb/s
encoded 1442 frames, 31.86 fps, 3974.08 kb/s
encoded 1442 frames, 32.03 fps, 3974.08 kb/s
Yes, DRAM Frequency = 400.9Hhz to be exact.Originally Posted by graysky
Soopafresh:
And my desktop computer:
Athlon 64 X2 3800+ Manchester
10 x 200 MHz
2GB 2.5-3-3-7 DDR 167MHz
Nvidia nForce4
Windows XP Pro SP2
encoded 1442 frames, 18.59 fps, 3905.08 kb/s
encoded 1442 frames, 18.44 fps, 3905.08 kb/s
encoded 1442 frames, 18.62 fps, 3905.08 kb/s
encoded 1442 frames, 4.55 fps, 3942.92 kb/s
Baldrick said -
Soopafresh: ieek.gif smile.gif
I know. It's not mine, it's the fastest computer at work. If I added my home computer to this test, the result would be in frames per day (fpd)
CPU: Intel Core 2 Duo E6600
Code name: Conroe
Core Speed: 3059.9 MHz
Multiplier x Bus speed: 9.0 x 340.0 MHz
Motherborad: ASUS P5B-Deluxe
Memory: 5-6-6-18
OS: XP SP2
encoded 1442 frames, 33.56 fps, 3905.08 kb/s
encoded 1442 frames, 33.50 fps, 3905.08 kb/s
encoded 1442 frames, 33.44 fps, 3905.08 kb/s
encoded 1442 frames, 33.52 fps, 3905.08 kb/s
encoded 1442 frames, 8.55 fps, 3942.92 kb/s
encoded 1442 frames, 8.53 fps, 3942.92 kb/s
encoded 1442 frames, 8.54 fps, 3942.92 kb/sSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
@Soopafresh- thanks man, that system is smokin'
@Baldrick - thanks again, got it.
@Chrissyboy - Cool man, got it, just one question... what frequency is your RAM clocked at?http://encoding.n3.net <-- for all your DVD and CD backup needs!
Sorry... Memory Frequency: 340.0 MHzOriginally Posted by graysky
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
That AMD Phenom proc that redwudz is using seems to be very fast for the money. It's up there with the Q6600 in fps encoding speed, but it's $70 cheaper that the Q6600 on NewEgg. That MacPro at work is a screamer, but the cost/performance ratio is nowhere near the other machines posted above. It's around 2.5x faster than a nice Q6600 system, but it's 4.5x the price.
@Soopa - yep, it seems like you'll always pay a major premium for that last 5-10 % on the price/performance curve
Intel Pentium D 935 Presler 3.2GHz
Intel DG965WHMKR Motherboard
2GB G.SKILL DDR2 800
Timing 5-5-5-15
Windows 2000 SP4
encoded 1442 frames, 18.28 fps, 3905.08 kb/s
encoded 1442 frames, 18.33 fps, 3905.08 kb/s
encoded 1442 frames, 18.32 fps, 3905.08 kb/s
encoded 1442 frames, 4.52 fps, 3942.92 kb/s
encoded 1442 frames, 4.51 fps, 3942.92 kb/s
If I could find a motherboard for my Socket 478 3.2 Pentium 4 I'd run a test for it.
x264 Encoding Help
By Trismegistus in forum Video ConversionReplies: 14Last Post: 28th Apr 2012, 08:55 -
Follow-up: x264 CPU usage--threads vs. instances
By Calidore in forum DVD RippingReplies: 26Last Post: 12th Feb 2010, 19:24 -
Best CPU chart for x264 HD Video Encoding Performance
By INFRATOM in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Feb 2009, 22:55 -
x264 CPU benchmark - Compare different CPUs encoding the same file
By graysky in forum ComputerReplies: 108Last Post: 16th Dec 2008, 01:19 -
x264/720p CPU requirements
By RB4891 in forum Media Center PC / MediaCentersReplies: 3Last Post: 15th Jun 2007, 07:31
