I'm trying to work with an MPEG-2 file that has AC3 audio - I can get the video to open in TMPGEnc via the MPEG-2 video plugin (m2v.vfp) but I can't get the audio to open - I get the error "File can not open, or unsupported". I have the AC3 ACM installed on my system and I know it works because I can play the video file through Media Player. I've tried bumping up the priority of the "DirectShow Multimedia File Reader" in the VFAPI plug-in list, but that didn't work.
As a workaround, I used VirtualDub-MPEG2 to extract the audio from the MPEG-2 file to a WAV file and then imported the WAV file into TMPGEnc, but when I encode a file, the A/V sync is horribly off (5 seconds or more) and I really don't feel like dealing with that.
Is there any way TMPGEnc can open AC3 audio directly?
Results 1 to 15 of 15
Maybe newer versions of the TMPGEnc encoder programs can open AC3, but the ones I've used can't. Why not just demux out the AC3, then add it back with the video after encoding?
BTW, which specific TMPGEnc program are you using? There's quite a few programs with that name. -
Use DGIndex to demux. When set up "properly" it will give you a video only file, an audio only file and a D2V project file.
I am using TMPGEnc Plus 2.5.
The problem with demuxing is that I'm actually going to be extracting smaller video clips out of the big one (it's the Super Bowl, fyi), so that's going to create more problems later I think with lining up the audio and video correctly.
Is there really no way to get TMPGEnc to read AC3? Also, do you guys think I'm using the wrong tool? Is there a better one I should be using? -
Well for editing I suggest MPEG-VCR or VideoReDo as both can edit MPG files that are MPEG-2 with AC-3 audio. This is done without any re-encoding except at the edit points and that ain't no big deal.
Thus you can do what you want without any re-encoding being done and that is KEY to a project like this although you haven't told us what your final format will be.
Originally Posted by TheEvilHammer
If I have to use TMPGenc to re-encode an MPEG wioth AC3, I use any of several decoders to convert AC3 to PCM or other Windows format, then re-encode to AC3 when I assemble the final video in TMPGenc's editor. Re-encoding MPEG isn't a good idea anyway. If you really must do a lot of color-correcting, convert first from MPEG to AVI, do your stuff, then use TMPGenc's stuff to go back to MPEG.
If all you want to do is cut up some MPEG without re-encoding it, just get TMPGenc's MPEG Editor. -
Eventually, I will be creating a DVD with this video, so I'm basically going from MPEG-2 with AC3 to MPEG-2 with probably MP2 audio. I need to re-encode because I have to downsize to the correct resolution (with some letterboxing) and drop the framerate from 60fps to 30fps (this is video I snagged off my DVR).
TMPGEnc-Author 3 will do all this for you. Not cheap, but it's a very robust editor and conversion platform.
Oh I don't have to do that, but I definitely need to downsize the resolution and framerate.
Demux with DGIndex. Allow it to demux the AC-3 audio and create a D2V project file. You don't really need to make a separate video only file as TMPGEnc Plus 2.5 should accept the D2V project file.
Re-encode the video giving yourself a video only file (M2V) and then join it back up with the AC-3 audio using whatever DVD Authoring program you intend to use.
Right, FulciLives, that seems like a good way to go considering the 60fps problem. I'd still advise the original post to keep TMPGenc and get their editor for the final output. I've done some fancy footwork in-between with lots of videos, but I find their encoder and editor hard to beat.
TheEvilHammer,
If you really want to use TMPGenc 2.5 for your editing you can use DGIndex as suggested earlier. One of its demux options is to output the audio to wav. Once its a wav, then you can easily open it up with TMPGenc and edit as you normally would.
Or if you really want MP2 audio (I also use for all my home made DVDs from captures, never had a compatibililty issue..), using DGIndex demux the native ac3 and use something like besweet to convert from ac3 to mp2. Quick and easy.
Either way, you'll have the video and audio ready for TMPGenc.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Hey thanks for all your suggestions guys!
After playing around with various tools for several days, I think I've found a process that will work:- I use ProjectX to demux the transport stream that I get from my DVR (I need ProjectX, rather than DGIndex, because ProjectX corrects the various problems in the stream and keeps A/V sync).
- I use TMPGEnc to work with the video file only, and drop the framerate, resolution, and bitrate to match DVD standards.
- I will probably use TMPGEnc DVD Author (or maybe VideoReDo) to remux the video and the AC3 file and edit out the commercials.
AVI (with Ac3 audio) to DVD using TMPGenc 2.5 Plus
By CaptainChaos in forum Authoring (DVD)Replies: 7Last Post: 2nd Mar 2012, 07:03 -
MuxMan 0.16.7 will not open AC3 audio file.
By Nagashi in forum AudioReplies: 9Last Post: 27th Jul 2010, 10:29 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 08:36 -
cannot open video only audio (tmpgenc xpress)
By bizt_uk in forum Video ConversionReplies: 3Last Post: 21st Nov 2008, 13:31 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23
