Hi,
would you happen to know if its possible to add letterbox bars to a widescreen videosource, in AutoDesk Cleaner?
I have been looking through the manuals but not found anything. I also know that they market the product with the feature "letterbox removal", but as you understand i need to do the exact opposite and i cant find any information on it. I dont find any functions for it in the program.
We need to go from a 1024 x 576 video source to a normal PAL image, i suppose thats 720 576 ... (so we will also downscale). Not the best solution but we are gonna do this for a limited time.
What is the output for ? If it is for DVD, then resize to 720 x 576 and encode as 16:9 and it will display correctly. If you need a 4:3 letterboxed image then resize to 720 x 448 and add borders. Don't know if cleaner can do this directly (haven't used it in years), but avisynth can do this very easily, and cleaner should then be able to encode from the avs file.
A simple script would look like this
DirectShowSource("path to your video/video filename")
Lanczos4Resize(720,448,5,0,1013,576)
AddBorders(0,64,0,64)
#Trim(0,5450).FadeOut(150)
ConvertToYUY2() # For VirtualDub or CCE
No the output isnt for DVD, i'd say its more for some treatment before being incorporated in a broadcast... and "the people on the other side" have specifically asked for a 4:3 letterboxed version.
Your avisynth approach was very interesting, I never thought of that. I dont think i'll be allowed to install extra software here though, which is why i asked about cleaner only. But i'll keep it in mind if things change. Thanks!
An analysis of "static bars" error needed
By moxiecat in forum RestorationReplies: 10Last Post: 20th Feb 2011, 15:48 -
"Theatrical Matte" subtitle
By ecc in forum SubtitleReplies: 4Last Post: 15th Dec 2009, 12:32 -
how to create "letterbox" bars with Total Video Converter
By zomigi in forum Video ConversionReplies: 6Last Post: 31st Jul 2007, 09:47 -
Any Program to "blank out" or "black out" a portion of
By mbextreme in forum EditingReplies: 6Last Post: 18th May 2007, 04:04 -
Cropping "Letterbox" Problem
By KatCassidy in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 9th May 2007, 08:48
Statistics
Newest guides
Latest tool updates
New media comments
