I have a Time Warner Cable TV account and a Scientific Atlanta Explorer 8300HD (160 GB HD) and I record some HD shows, then pipe them out to my Plextor ConvertX PX-M402U. I then boot into Xpro, run SageTV 6.3 and capture the file, and edit with womble MM editor. The problem is that I get gray bands across the top and bottom of the output files. Check out this screenshot: screenshot1.png Can't fix this in Womble. So I boot to Linux Mint and AviDemux, load the file, apply a crop filter, removing 64 from top and bottom and the preview looks good.
But when I save the file, the bands are still there.
Does anybody have some choice words of wisdom or suggestions regarding my convoluted and tedious, unsuccessful method(s)? Frankly, my friends, I'm getting tired of hard, and want to start working smart. At first I noticed that working hard was character building. But it soon become a repetitious exercise in futility. Any comments are welcome.
And why isn't AviDemux filter being applied on save? Anything else I could try? I can use CLI.
Results 1 to 24 of 24
..and from the gods we've stolen pi, two times again our radii. the glyphs of mice and men we read, the darkness in our souls stampede....
Linux bc calculator can display pi to enormous precision: bc -l; scale = 500; 4*a(1)
I don't think I fully under stand the problem you're having.
What I gather from your post, is -
8300HD is outputing 16:9 content, you are capturing this content with the Plextor in 4:3 format. And don't like the fact that when you capture 16:9 content with a 4:3 device, it puts black bars on the top and bottom?
Now, what is you final goal? DVD? XviD, x264?
If you are wanting to output back to DVD, but have it actually in 16:9 format, crop the top and bottom of the black bars, resize to 720x480, encode as 16:9.
ffmpeg -i file.mpg -croptop 64 -cropbottom 64 -s 720x480 -aspect 16:9 -target dvd-ntsc output.mpg
Want something a little more complicated?
mkfifo video.yuv
mplayer -noconsolecontrols -benchmark -nosound -noframedrop -noautosub -vo yuv4mpeg:file=video.yuv capture.mpg \
-vf crop=:352::,scale=720:-2:0:0:0.00:0.75:ntsc:0:0,fspp=5::6::,unsharp=l3x3: 1.20:c3x3:0.50,expand=720:480 & \
cat video.yuv | yuvdeinterlace -S 0 | yuvdenoise* -G 2,3,3 | mpeg2enc -f 8 -a 3 -g 3 -G 18 -4 1 -2 1 --cbr -b 5500 -R 2 -K tmpgenc \
-o output.m2v
* yuvdenoise changed it params in the newer release candidates, older than 1.9 would use yuvdenoise -s 2,3,3 -g 32,128,128 -t 3,4,4, and you may need to adjust the crop value. 352 would chop 64 from the top and bottom (480-64-64=352). You could also remove yuvdeinterlace, and keep the footage interlaced, or add yadif to the mplayer filter chain. You can add remove any filter needed, either y4m/yuv filters or mplayer filters.
When that file is played back on a 4:3 monitor or tv, it will append the black bars. Remember watching 16:9 DVDs on a sqaure TV? When the file is played back on a wide screen TV/Monitor, there will be no black bars.
You're best bet might be to encode to XviD or x264. Check these programs that do a bang up job - http://xvidenc.sourceforge.net/Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
SA cable boxes convert 16:9 HD to letterboxed 4:3 SD at the s-video and composite outputs. Your computer is just capturing what the box is putting out.
Now I understand that the Plextor video capture device is receiving a letterbox output. I want to archive some TV shows and squeeze them down with h.264. I will never copy them to a DVD, but they must be in a format easily recognized by Linux vlc or mPlayer.SA cable boxes convert 16:9 HD to letterboxed 4:3 SD at the s-video and composite outputs. Your computer is just capturing what the box is putting out.
disturbed1's ffmpeg cli works fine: ffmpeg -i file.mpg -croptop 64 -cropbottom 64 -s 720x480 -aspect 16:9 -target dvd-ntsc output.mpg
But the file size grew from 2.5 GB to 17.7 GB.
Then I tried adding h264 compression ffmpeg -i file.mpg -croptop 64 -cropbottom 64 -s 720x480 -aspect 16:9 -target dvd-ntsc -vcodec h264 output.mpg and it bombed:
Code:rmack@rochester:~/temp$ ~/h264_16x9.sh FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al. configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libogg --enable-libgsm --enable-dc1394 --disable-debug --enable-libmp3lame --enable-libfaadbin --enable-libfaad --enable-libfaac --enable-xvid --enable-x264 --enable-liba52 --enable-amr_nb --enable-amr_wb --enable-shared --prefix=/usr libavutil version: 1d.49.3.0 libavcodec version: 1d.51.38.0 libavformat version: 1d.51.10.0 built on Dec 20 2007 21:25:50, gcc: 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2) Input #0, mpeg, from 'Banned From the Bible II.mpg': Duration: 01:27:53.1, start: 0.169900, bitrate: 3869 kb/s Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 6400 kb/s, 29.97 fps(r) Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 384 kb/s Assuming NTSC for target. File 'Banned From the Bible II-1.mpg' already exists. Overwrite ? [y/N] y Output #0, dv, to 'Banned From the Bible II-1.mpg': Stream #0.0: Video: h264, yuv420p, 720x480, q=2-31, 200 kb/s, 29.97 fps(c) Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s Stream mapping: Stream #0.0 -> #0.0 Stream #0.1 -> #0.1 [h264 @ 0xb7e22a68]using SAR=32/27 [h264 @ 0xb7e22a68]using cpu capabilities MMX MMXEXT SSE SSE2 [dv @ 0xb7f15610]Can't initialize DV format! Make sure that you supply exactly two streams: video: 25fps or 29.97fps, audio: 2ch/48Khz/PCM (50Mbps allows an optional second audio stream) Could not write header for output file #0 (incorrect codec parameters ?)..and from the gods we've stolen pi, two times again our radii. the glyphs of mice and men we read, the darkness in our souls stampede....
Grab h264enc. It will make your life easy
http://h264enc.sourceforge.net/
Grab the latest tarball, extract it to a directory, and run it (from the cli) from there. No need to install.
./h264enc --help
Will give you lots of information.
./h264enc -sc
Performs a check to see what programs you have installed
I usually just use
./h264enc -1p -p uhq
Which will do a one pass encode with ultra high quality.
You can also try
./h264enc -1p -p hq
Which give you a simple one pass encode at high qualityLinux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
LOL! I'm still in a pickle!
I had a letterboxed file.mpg sized 2.5 GB. I can remove the letterbox bands and resize it with ffmpeg -i file.mpg -croptop 64 -cropbottom 64 -s 720x480 -aspect 16:9 -target dvd-ntsc output.mpg , but the filesize grows to 17.7 GB. That's too big. Or I can run h264enc -1p -p hq which squeezes the down to a nice 700 MB size, but retains the letterboxing bands.
I want to do both compressing and cropping in one pass, preferably w/o pipling, because piping is incompatible with h264enc.
There seems to be an option that would enable cropping in the h264enc script:
But I am not sure how much cropping can be done without breaking the encoder. Any ideas?Code:Would you like to Crop the video file? [y/n]: y -> Detecting crop values with 'cropdetect'... -> Found crop values: 704:464:6:8 Specify the crop values [default is 704:464:6:8]:
Specify the crop values [default is 704:464:6:8]:720:352::
Yes there are 2 : after 352. So that's ::
Originally Posted by man [url=http://www.videohelp.com/tools/MPlayerLinux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Tried your suggested resize to 720:352:: and the preview from the h264enc script looked fine; the black lines were removed. However the resultant file was unplayable and only 4.0k in size.
I never suggested a resize, it was a crop
There's a difference between crop and resize, as there is between .mpg and .mp4, .avi, .mkv (which is the container x264 files need to go in).
The preview worked, and looked correct, so the crop settings where passed correctly. Sounds like a bad option somewhere was passed. Giving a 4k file means mencoder didn't even encode the file, it instantly bailed. h264enc has the option to both inspect the command and save the command.
./h264enc --help
man mplayer
There isn't honestly anything I won't tell you that isn't in those 2 pieces of documentation
I'd spend the 5 minutes and see what they have to say
I looked at the mencoder script generated by h264enc and it appears impossible for a person of my modest abilities to parse. I guess I know when I'm licked.
mencoder "/home/rmack/temp/test-5.mpg" -o "/home/rmack/temp/test-5.avi" -vf crop=720:352::,softskip,harddup -oac faac -faacopts mpeg=4:br=110
bject=2 -ovc x264 -x264encopts bitrate=1000:me=umh:me_range=16:nodct_decimate:noi nterlaced:8x8dct:threads=auto:nofast_pskip:trellis =1
artitions=p8x8,b8x8,i8x8,i4x4:mixed_refs:keyint=30 0:keyint_min=30:frameref=3:bframes=14:bime:b_adapt :b_pyramid:weight_b:direct_pred=auto
ubq=5:nobrdo:chroma_me:cabac:deblock:nossim:nopsnr
This, of course, crashes mencoder instantly without processing the file as desired...and from the gods we've stolen pi, two times again our radii. the glyphs of mice and men we read, the darkness in our souls stampede....
Need an engineering degree for that sucker don't youOriginally Posted by Verlager
What I do, when I don't understand one of the options passed is look it up in the man page.
man mplayer
You may not know this, but there is a man for man
to search inside a man page type / a text entry will appear to type in. Use the n
key for next, p for previous entry. PgUp/Down as Home/End also work naviagting.
Copy and paste the following, to see how it goes.
mencoder "/home/rmack/temp/test-5.mpg" -o "/home/rmack/temp/test-5.avi" -vf crop=720:352::,yadif,softskip,harddup \
-oac copy -ovc x264 -x264encopts \
bitrate=1000:me=umh:me_range=16:nodct_decimate:8x8 dct::nofast_pskip:trellis=1
artitions=p8x8,b8x8,i8x8,i4x4:mixed_refs:\
keyint=300:keyint_min=30:bframes=3:bime:b_adapt:b_ pyramid:weight_b
ubq=5:nobrdo:chroma_me:cabac:\
Mencoder will either process, or send some type of error. Sigterm, can't open -vf, something........
The only thing I changed from h264enc is adding the yadif deinterlancer, lowered the number of b frames, removed faac encoding.
Faac encoding can be buggy if you don't have the right bins/libs. It will encode a little slow
The \ at the end of the lines creates a line break. That way everything doesn't run together as one great big huge line.
You can try to use the default x264 options as well -
mencoder inpuptfile.mpg -ovc x264 -oac copy -vf crop=720:352::,yadif -x264encopts bitrate=1000 outfile.avi
That's just a basic script to use all of the default x264 options with a bitrate of 1000, crop 64 pixels from the top and bottom, deinterlace.
If you're tired of all this scripting
winff is a nice program as well. It has basic options and presets ready for you, but now
that you know a few options, you can customize it your self
Thank you for your input. It is appreciated. The first suggestion bombed:
-as did the second:Code:rmack@rochester:~$ mencoder "/home/rmack/bin/test-5.mpg" -o "/home/rmack/bin/test-5.avi" -vf crop=720:352::,yadif,softskip,harddup -oac copy -ovc x264 -x264encopts bitrate=1000:me=umh:me_range=16:nodct_decimate:8x8dct::nofast_pskip:trellis=1:partitions=p8x8,b8x8,i8x8,i4x4:mixed_refs:keyint=300:keyint_min=30:bframes=3:bime:b_adapt:b_pyramid:weight_b:subq=5:nobrdo:chroma_me:cabac: deblock:nossim:nopsnr MEncoder 2:1.0~rc1-0ubuntu13.1 (C) 2000-2006 MPlayer Team CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (Family: 6, Model: 15, Stepping: 11) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled with runtime CPU detection. Option x264encopts: Unknown suboption success: format: 0 data: 0x0 - 0x144e638 AVI file format detected. VIDEO: [MPEG] 720x480 24bpp 29.970 fps 4764.5 kbps (581.6 kbyte/s) [V] filefmt:3 fourcc:0x4745504D size:720x480 fps:29.97 ftime:=0.0334 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [harddup] Opening video filter: [softskip] Opening video filter: [yadif] Opening video filter: [crop w=720 h=352] Crop: 720 x 352, -1 ; -1 ========================================================================== Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2)) ========================================================================== audiocodec: framecopy (format=50 chans=2 rate=48000 bits=16 B/s=48000 sample-1) VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12) Could not find matching colorspace - retrying with -vf scale... Opening video filter: [scale] VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect. SwScaler: using unscaled yuv420p -> yuv420p special converter FATAL: Cannot initialize video driver. Exiting... rmack@rochester:~$
Winff is a nice gui for ffmpeg, but it doesn't allow for cropping, AFAIK, and I have tried it. BTW, this mencoder CLI syntax should be more forgiving, users should be allowed to use abbreviated syntax:Code:rmack@rochester:~$ mencoder /home/rmack/bin/test-5.mpg -ovc x264 -oac copy -vf crop=720:352::,yadif -x264encopts bitrate=1000 -o /home/rmack/bin/test-5.avi MEncoder 2:1.0~rc1-0ubuntu13.1 (C) 2000-2006 MPlayer Team CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (Family: 6, Model: 15, Stepping: 11) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled with runtime CPU detection. success: format: 0 data: 0x0 - 0x144e638 AVI file format detected. VIDEO: [MPEG] 720x480 24bpp 29.970 fps 4764.5 kbps (581.6 kbyte/s) [V] filefmt:3 fourcc:0x4745504D size:720x480 fps:29.97 ftime:=0.0334 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [yadif] Opening video filter: [crop w=720 h=352] Crop: 720 x 352, -1 ; -1 ========================================================================== Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2)) ========================================================================== audiocodec: framecopy (format=50 chans=2 rate=48000 bits=16 B/s=48000 sample-1) VDec: vo config request - 720 x 480 (preferred colorspace: Planar YV12) Could not find matching colorspace - retrying with -vf scale... Opening video filter: [scale] VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect. SwScaler: using unscaled yuv420p -> yuv420p special converter x264 [info]: using SAR=8/9 x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2 Pos: 0.0s 1f (99%) 0.00fps Trem: 0min 0mb A-V:0.000 [0:0] Flushing video frames Writing index... Writing header... ODML: vprp aspect is 16384:9011. Video stream: nan kbit/s (-2147483648 B/s) size: 0 bytes 0.000 secs 1 frames Audio stream: 384.000 kbit/s (48000 B/s) size: 24000 bytes 0.500 secs x264 [info]: final ratefactor: 22.20
mencoder input.mpg -o output.mpg vf crop=720:352::,yadif -which, of course, is nonsense. I just think this 1970's CLI voodoo is not as user-friendly (yes, I see your signature) as it might be...and from the gods we've stolen pi, two times again our radii. the glyphs of mice and men we read, the darkness in our souls stampede....
Mencoder is not included in that statementI just think this 1970's CLI voodoo is not as user-friendly (yes, I see your signature) as it might be.
In my opinion, x264 is bailing on you. 1 of 2 things, mencoder/mplayer outdated, x264 outdated. Using Ubuntu, the only solutions,
are to work around it, or compile your own. Mplayer/mencoder isn't that out of date, so we'll leave it alone.
The first command (from h264enc) failed because it passed options that your x264 doesn't support. The second failed
because I have no idea
You can crop with winff. Click view, check additional options. Add this to the additional Command Line Parameters (advanced)
IF winff fails as well with x264 encoding, you'll either have to just use xvid, or compile a new x264. It is quite easy to compile x264.
I'll type this out for the CLI, just because it easier than typing click this, that, choose this that....
Code:cd $HOME/Desktop wget ftp://ftp.videolan.org/pub/videolan/...5-2245.tar.bz2 tar -xf x264-snapshot-20080315-2245.tar.bz2 cd x264-snapshot-20080315-2245 ./configure --enable-pthread --enable-shared --prefix=/usr make -j4 sudo make install sudo ldconfig
Line by line -
Changes directory to the current user's home, then Desktop directory.
Downloads the daily snap shot of x264 (03-15-2008)
Extracts the tarball
Changes into the directory of the newly extracted tarball
Configures x264 to use multithreads, creates shared libraries, with the install prefix of /usr (Standard for Ubuntu)
Compiles the source using your 4 cores.
Becomes root to install the newly created files.
Root once again updates all linked (shared) libraries.
------------edit----------------
Does this file you're trying to encode play with mplayer/VLC? I guess that should of been the first thing, but just covering all bases here.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
This takes too many steps to save and compress a file. Can anyone comment on this cumbersome method?
I. I record the HD cable TV signal to the SA cable box, which converts 16:9 HD to letterboxed 4:3 SD at the s-video and composite outputs.
II. I pipe the two-hour, 4 GB file to my computer with this shell script:
III. I use avidemux to load the file, remove the black bars with a crop filter, change the codec to mpeg, and save the file down to 2.5 GB.Code:#!/bin/bash bitrate=1750 mode=ntsc #format=mpeg2-dvd format=mpeg2 duration=`expr $2 \* 60` input=0 gorecord -input $input -duration $duration -bitrate $bitrate -mode $mode -format $format $1.avi
IV. Then I use winff to transcode to h.264 mp4 ipod 16:9 preset. The file is now 1.1 GB
This works. Avidemux encodes it accurately, even the audio is correct. But what shortcut am I missing? What steps could be eliminated safely to streamline this complex process? Steps I and II are needed as is. It's steps 3 and 4 that might be tweaked. Anybody have any ideas? Is there a better and safe avidemux codec and container combo to use?..and from the gods we've stolen pi, two times again our radii. the glyphs of mice and men we read, the darkness in our souls stampede....
You can use AviDemux to do steps 3 and 4 at the same time. It can output h.264+AAC in an MP4 container. You just have to use settings suitable for your player.
Not exactly... If you select x264 from Avidemux, the filters are disabled. Tell me if I'm mistaken.
I've never had that happen. Although, I've only used the Windows version.Originally Posted by Verlager
Huh. And the Linux Avidemux doesn't support the .mkv container. That could have helped.
I off-loaded the task to the bedroom office Q6600 Linux Mint machine and it worked. Thank you so much for the tip!
I hope I can get crisper with avidemux...and from the gods we've stolen pi, two times again our radii. the glyphs of mice and men we read, the darkness in our souls stampede....
So is it just a version number difference?
Im trying to extract part of this flv video and im using WinFF, does anyone know if it is possible to just grab a section of the video and encode just that part?
afaik ffmpeg doesn't support encoding of only a section (while mencoder do)
you can try using avisynth and ffmpeg
using a script like
directshowsource("test.flv")
trim(1500,3000) # for keeping from 1500' frame to 3000' frame
if ffmpeg is compiled with avs support, you will be able to encode this script
using WINE of course..
BHHHDConvertToX, AutoMen, AutoMKV Developer
On my 3 Freeview boxes that I've had and the sky and sky+ boxes, if I told them that they were outputting to a 16:9 TV even though they were actually connected to either a Liteon DVD recorder or a Hauppauge capture card (both of which only capture 4:3), the picture would be recorded as a vertically stretched 16:9 picture that filled the screen. Once this video is on the computer you either save from your editing software with the 16:9 option ticked or use DVD Patcher to change a flag in the file's header so that it becomes widescreen again. Check the settings on your cable box and make sure that they're set to output to 16:9 devices.
Hope this is of some help
Unless there is some hidden menu somewhere Scientific Atlanta cable boxes don't have the option of squeezing a 16:9 image into the s-video or composite outputs. They always letterbox.
Corel VideoStudio Pro X5 is adding lines in top and bottom of the video
By 192837465 in forum EditingReplies: 13Last Post: 19th Apr 2012, 23:46 -
Can I remove black bars (top and bottom) when backing up my dvd's?
By jammiev in forum DVD RippingReplies: 10Last Post: 17th Jan 2012, 13:19 -
When 16:9 isnt 16:9. Black bands top and bottom.
By agoldfish in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2011, 11:18 -
Black borders at the top and bottom of Video
By Maikeru-sama in forum Video ConversionReplies: 7Last Post: 23rd Jul 2008, 20:21 -
Why do some Widescreen Movies still have black bars top and bottom?
By the_importer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Dec 2007, 09:09
