Can anyone point me in the direction of a silver inkjet printable DVD that has the hub covered as well.
Everything I can find says hub printable but when you look at it, the DVD has a clear middle ring. It can be DVD+R or DVD-R
Thanks in advance.
I'm not aware of any silver DVDs that are hub printable, though they may be out there. I would also confine my search to reputable brands like TY or Verbatim, or similar, or you may end up with a fine print job, but a trash disc.
On the other hand, most white surface discs seem to be hub printable.
http://www.supermediastore.com/taiyo...printable.html
meritline did not have hub printable TY media. Nor did rima.com;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
I bought them and will post back!!
Haven't had a coaster yet
They print pretty good
The hub takes ink differently than the outside but they are the only ones that meant my needs.
http://www.rima.com/Merchant2/mercha...ory_Code=DMRTYOriginally Posted by classfour
http://www.meritline.com/taiyo-yuden...printable.html
Hi, Gen-An.
Thank's for the links. I liked them.
Templates for popular printable DVD media
By stiltman in forum MediaReplies: 60Last Post: 4th Jan 2011, 08:20 -
Glossy hub printable DVD+R
By PharmBoy in forum MediaReplies: 9Last Post: 27th May 2008, 08:06 -
TY R47WPP600SK -- hub printable or not?
By spiffy in forum MediaReplies: 6Last Post: 12th Mar 2008, 21:03 -
Dual Layer hub printable media??
By garstan in forum MediaReplies: 4Last Post: 21st Oct 2007, 14:50 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 10:29
