Hello,
I'm trying to get dvdrebuilder to work in wine. I know that it works for others but for some reason I'm getting no joy. It installs just fine but when I try to start it I get "starting DVD Rebuilder" for a few seconds then nothing.
I have followed the instructions here. I also copied the following files into the system32 directory of wine.
There were a few of those files already in the wine system32 directory so I didn't replace those files. Should I have?Code:mfc42.dll, msvcp60.dll, advpack.dll, asycfilt.dll, comcat.dll, msvbvn60.dll, oleaut32.dll, olepro32.dll, stdole2.tlb. All of these need to be placed into the .wine\drive_c\windows\system32 folder
Any help would be appreciated!
Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Run it from the command line to get the error message for the missing/faulty dlls. You'll want to cd to $HOME/.wine/drive_c/Program\ Files/whatever and run it from there
wine dvdrebuilder.exe (or whatever it's called)
http://forum.doom9.org/showthread.php?t=120107 on DVD Rebuilder and wine.
Can't say I've personally used the program since it first came out (how many years ago?). I'm the manual type of person myself. Although I did run doitfast4u with wine a year or 2 ago. I've managed to get native Linux tools to (somewhat) get the same job done.
Haven't used wine since I moved to 64bit. Not missing it either
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Thanks for the tip of starting with terminal. It did help to solve the problem. Even though I followed the tutorial correctly it seemed there were problems with OLEAUT32.dll loading so I copied that from my windows partition and replaced wine's copy of OLEAUT32.dll (after making a copy first!) and it worked.
Once again many thanks Disturbed1. I am learning a lot from your posts!Donadagohvi (Cherokee for "Until we meet again")
Love those easy fixes
Every program I launch for the first time, I always do it from the command line. Just to read the output, and see whats going on.
Helps to trouble shoot some issues. Like why Avidemux xvid encoding was so slow in Ubuntu. It was using an old version of the codec that didn't support multi-threading.
It's even so much more helpful when attempting to get stuff to run with wine.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Powerpoint won't run in Wine
By Webster in forum LinuxReplies: 2Last Post: 25th May 2011, 04:17 -
LG LRH-780 DVD Drive Problems..... Solved!
By dragon064 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Feb 2010, 19:59 -
[solved]Problems about transitions in DLP
By ihmcjacky in forum Authoring (DVD)Replies: 5Last Post: 2nd Feb 2009, 23:07 -
SubtitleCreator Problems (Solved)
By TRUSTpunk in forum SubtitleReplies: 9Last Post: 8th Aug 2007, 12:05 -
Problems running Vegas 6 with Windows XP X64 Pro
By aplhunter in forum ComputerReplies: 1Last Post: 22nd Jul 2007, 09:21
Statistics
Newest guides
Latest tool updates
New media comments
