Hi All,
just coming back from a trip where I've recorded more than 10 GB pf stuff
I would like to create one ( max 2) single DVD and I wonder if there is a simple (very simple, I am so dummy...) software which allows to creat it from a Sony Handycam ( the most complete and simplest)
a friend of mine, months ago showed me a very very nice DVD with animation, sort of cartoon with funny words on the photo but I don't remember the name of the program that he used
Since he is so ignorant in editing like me...........
thanks in advance for your help
Thread: handycam
ConvertXtoDVD - it is the very simple. Your friend did not use it for sure - this stuff is by far very simple.
That is very simple and very nice don't come together.
I'm assuming a DV camcorder. If so, you'll need a FireWire card or input on your PC, along with the FireWire cable. WinDV works well for transferring to your hard drive. With DV, one hour per DVD should give you the best quality, but you can get two hours on there in good quality with some care at encoding.
For simple, you could try ConvertXToDVD. If you need to do some editing, one of the 'package' programs with editor, encoder and authoring would work well. For cheap, VirtualDub or Windows Movie Maker for edits, output as DV to a encoder. FAVC is a great freeware program to do the DVD conversion.
simply ask your friend
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
zoobie
you are a genius!!!
my friend died 2 wks ago......
Marlo, start with identifying the camcorder model and the format of the video. How do you know that it is 10 GB?
http://www.kiva.org/about
Old Sony Handycam to PC
By cincy_kid in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 26th Jul 2011, 23:05 -
Want to Upgrade my Sony Handycam
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD)Replies: 13Last Post: 9th Jun 2011, 10:34 -
How can I tell if my Handycam is an NTSC or Pal ?
By morabet in forum Newbie / General discussionsReplies: 6Last Post: 27th Aug 2008, 08:41 -
Sony Handycam DVD508
By snakeplkn in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2007, 18:20 -
HandyCam Cables?
By Guiboche in forum Camcorders (DV/HDV/AVCHD)Replies: 10Last Post: 8th May 2007, 15:50
