I have a problem.. I bought a 12 foot dvi to component cable on ebay to hook my video card up to my tv (my dvd player uses the dvi port and the only other input i can use is component) but the image is showing up all scrambled. I downloaded a couple programs like powerstrip to try and play with different refresh rates and resolutions but nothing seems to be working. this is my tv: http://www.soundandvisionmag.com/equ...v-monitor.html
my video card is a radeon x800, i'm connecting it to my tv through the dvi port on it for secondary monitors. any help you can give me would be great!
Thread: Scrambled picture from tv-out
sorry I forgot to mention that the cable is actually a component to vga and i am using a vga to dvi adapter on it to connect it to my card. not sure if that matters...Originally Posted by bizzle_613
Make sure the computer is sending a resolution and refresh rate your TV supports. The manual should give the details. Try something like 1024x768 at 60 Hz.
Mediainfo Export Files Appear Scrambled
By zoomie in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2012, 14:33 -
ANYDVDHD BD+ frames may be scrambled?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 21st Sep 2011, 20:43 -
Digihome backup scrambled TRPs
By nightskystar in forum DVB / HDTVReplies: 0Last Post: 6th Nov 2009, 14:59 -
Scrambled DVD
By thepopsicle in forum Software PlayingReplies: 3Last Post: 10th Jun 2009, 13:34 -
Scrambled DVD Playback
By shteeve in forum Software PlayingReplies: 2Last Post: 15th Dec 2008, 12:40
Statistics
Newest guides
Latest tool updates
New media comments
