I need a workflow or user guide to be able to go from an edited 16:9 HDV timeline in FCP to a 3:2 or 4:3 FLV file for embedding in a website. My 16:9 HDV was shot with a wide angle lens and has some shading in the corners of the frame, so I need to crop the sides off and keep the middle, hence the 3:2 or 4:3 output. I would like to keep the Hi-def if possible but if I must drop the HD timeline into an SD timeline and then scale it so be it. I'm looking for the best possible video quality I can get with a 512 kbps FLV output. Can anyone please help me, I am under a lot of pressure to get this out. Thanks.
I use a iMac G5 2.1 GHZ w/2.5 GB ram, and Final Cut Pro 5.4. I also have Sorenson Squeeze 4.5.
Results 1 to 1 of 1
HDV Capture problems in FCP
By birdfeeder in forum MacReplies: 16Last Post: 27th Jul 2011, 19:02 -
HDV Editing Workflow
By SCDVD in forum EditingReplies: 0Last Post: 18th Dec 2008, 13:20 -
Simple workflow for capturing and editing HDV from my Canon HV20
By pred02 in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 29th Aug 2008, 08:35 -
By SCDVD in forum Newbie / General discussionsReplies: 14Last Post: 25th Apr 2008, 16:05 -
Editing workflow for HDV/SD
By racer-x in forum Camcorders (DV/HDV/AVCHD)Replies: 9Last Post: 21st May 2007, 05:50
