Whenever I combine 2 or more .AVI files into one file, the size of the resulting file is always much, much larger than the sum of its parts, and I'm trying to find out why.
As an example, I combine 5 AVI chunks, each roughly 150MB, and end up with a 4.1GB file. The same thing happens if I combine 2 AVI files of about 600MB each - I still end up with a file that is around 4GB.
To join the video parts, I've used Nero Showtime, as well as Movavi Suite 5, with the same results. The video I'm combining is always different parts of the same video - that is, Homemovie1.avi, Homemovie2.avi, and so on. Different parts of the same source. Changing output quality from "Best" to "Normal" doesn't make a difference.
So why doesn't 600MB AVI + 600MB AVI = 1.2GB AVI? And, how can AVI files be combined without bloating to enormous size files?
Thanks for any help.
Use AVI Demux in Copy mode. Open the first file, then append the rest. If it asks you if you want to create timemaps or turn on smart rendering, say yes. Save you new file (remember to add .avi on the end of the name - AVI Demux doesn't do this) and you should have your new file.
All the other tools you have been using are re-encoding, and you don't seem to know how to set them up correctly.
If, however, you are converting for DVD, then expect the new files to be 3 - 4 times the size of the avi files if you want something like the original quality.
It must be a setting:
AVI (uncompressed) is 65Gig/hour
DV/AVI=30G/hour
What video properties are your original size and what properties are your finished video file?
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 15:40 -
Huge AVI file after mencoder encoding
By nickman00 in forum DVD RippingReplies: 3Last Post: 2nd Jun 2009, 18:57 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum CapturingReplies: 9Last Post: 13th Oct 2008, 15:38 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 07:32 -
larger file size from .avi to h264
By sai351 in forum Video ConversionReplies: 3Last Post: 4th Jun 2007, 13:20
Statistics
Newest guides
Latest tool updates
New media comments
