Hi all, I just bought Panasonic DMR-EZ27 and have a problem when I try to record some of the cable digital TV program. I can watch the show lively without any problem but when I record it and playback the recorded show, the video is absolutely great but the audio is either silent or got static noise. I tried to record analog program and some of the digital program , both are fine, works great. The problem only happens for some of the cable digital channels. I tried many times, on different time frame but the same problem occured.
I tried to upgrade the firmware, connect it to the TV with either composite and HDMI, disable/enable VSS, etc. but still have the same problem. Anyone has any idea what's the cause of the problem or how to fix it?? Many thanks!!
How are you connecting your Digital Cable source? Is it through coax or through RCA (Yellow, Red, White)? We need some more information before we can help you...
I don't think the problem lies between your cable box and the TV. We need to know how you are hooking up your cable box to your DVD recorder in order to help you more...
I don't have cable box at all. What I have is a very basic cable services which allow me to watch channel 1-99. With the ATSC digital antenna of the DVD recorder, I can watch some additional channels like ABC HD and some other un-scrambled digital channels.Originally Posted by driguy
So I use coax cable to connect from the wall jet to my dvd recorder, and use component cable to connect to my TV. I can watch all the channels, both analog/digital, without any problem. But if I record some of the digital channels, and play it back, the audio is gone. It only happens in some of the digital channels, I can record other dig channels without any issues.
Do you have another DVD recorder you can test with? I would try that in order to isolate the problem, in other words, is it my cable service OR is it my DVD recorder? Plus, you're hooking up with coax which is pretty flakey anyway, it would be better if you had an actual box from your cable company to see if your problem persists.
Panasonic DMR-EZ27 and EZ28 switches channels while recording
By dtsb52 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2009, 12:59 -
Panasonic DMR-EZ27 has lost its digital tuning capability
By Frank-0-Video in forum DVD & Blu-ray RecordersReplies: 13Last Post: 23rd Feb 2009, 18:26 -
Panasonic DMR-EZ27 Chip set?
By Deter in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Sep 2008, 18:26 -
panasonic dmr-ez27 and fixed hybrid vbr resolution ?
By hamilton accie in forum DVD & Blu-ray RecordersReplies: 4Last Post: 20th Jan 2008, 17:41 -
Panasonic LSI for DMR-EZ17,EZ27...?
By cosmin in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 22:17
Statistics
Newest guides
Latest tool updates
New media comments
