VideoHelp.com Forum
    First time with this strange issue on this GX 330 player/ recorder. Have recorded TV shows in the past.
    Attempted to time- record a TV show last night and when the recorder came on this message came across the screen. Thought it was the DVD and used a different brand: same message, then again, same message
    Had DVD time set to HSP and or SP for a 60 minute show. Thus enough time was allowed on the DVD
    The recorder seems to record but the DVD's remained blank. It finalizes as directed after 'recording' and all that (and even formats the DVD prior to recording after inserting the DVD) as required.
    At the end of the day: DVD is blank.
    But something about the 'signal' being unrecordable is baffling.
    I can monitor the TV via the GX 330 so the TV signal is good and viewable.
    What setting am I missing here?
    I had not adjusted anything to my knowledge since it worked fine in the past.
    Thoughts?
    Baffled Robert
    HP Pavilion DV 6928notebook, LG 37 H 30,
    LG BD 370 BluRay player
    Thoughts?
    Baffled Robert
    Also, the info about the show did show on the GX 330 information so some aspect of teh signal is getting though.
    Set up is 'cable in'.
    Baffled Robert
  3. Member olyteddy's Avatar
    There exists a 'flag' in TV now that can be set to 'Record Once' or 'Do Not Record'. Most DVD recorders respect this.
    Thank you. Turns out the DVD recorder does not record HD signals.
    I ought to have noted this factor in my query.
    Problem explained to me by SONY tech support.
    Cordially,
    Robert
  1. Replies: 12
    Last Post: 20th Mar 2012, 14:35
  2. Sony RDR-RXD890
    By dixons in forum DVD & Blu-ray Recorders
    Last Post: 12th Mar 2009, 23:37
  3. Is Sony RDR-HX720 compatible with Sony HT-SS2300
    By abdul_sma in forum DVD & Blu-ray Recorders
    Last Post: 6th Nov 2008, 09:14
  4. Sony RDR-VX530
    By tvlreject in forum DVD & Blu-ray Recorders
    Last Post: 5th Mar 2008, 20:40
  5. Sony RDR GX 330 problem with recording signal?
    By rjl24 in forum DVD & Blu-ray Recorders
    Last Post: 5th Mar 2008, 07:58
