When you double-click the video image in VLC (not the control bar) the view changes to fullscreen. I have to get rid of this behaviour. So it seems like I have to comment out some lines in the source code and rebuild it. Does anybody have any experience in doing this? I've heard rebuilding VLC under Windows XP Pro can be problematic. I would be thankful for any tips on what misstakes not to do.
SuSE 9.3 Pro
There are problems wile compiling VLC with MS Visual Studio. It can be compiled under Cygwin
lagu - i think you can redefine this behavior in settings. no need to rebuild the whole player
video is worth a thousand images
Hi,
I have posted the following query in couple forums, but didn't get solution so far.
I'm using winmm.dll to play wmv video. I wanted to find out wmv video Frame Rate and Frame Count of any user selected video. I'm wondering what is the API call in winmm will return those values? or any other way to find out?
I'm wondering, is this possible to do in VLC. I would have to call some commands from another s/w like play, playfrom(timecode), should able to find FrameRate and FrameCount.
appreciate your help.
How to play 4:3 Aspect ratio in fullscreen using VLC,MPCHC?
By skorpinok in forum Video ConversionReplies: 8Last Post: 3rd Sep 2011, 21:53 -
R-click context menu for VLC and WMP - not working
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 07:44 -
mouse double click is not responsive during recording
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jul 2009, 00:56 -
mouse double click is not working quite good during screen recording
By George2 in forum ProgrammingReplies: 5Last Post: 28th May 2009, 19:07 -
No Mouse Double Click Button in Windows 7 ?
By wulf109 in forum ComputerReplies: 2Last Post: 22nd May 2009, 12:59
Statistics
Newest guides
Latest tool updates
New media comments
