VideoHelp.com Forum
    HELP! !
    I got myself the LG RC797T to enjoy the 1080i upconvert and the QAM tuner to record channels I could not with my analog tuner VCR.
    First problem: the upconvert. All 4:3 content is STRETCHED ! How can I watch a TV show on DVD upconverted without it stretching it ? Why aren’t upconverted 4:3 signals pillar boxed ?!?!?!
    AND It turns out that I really didn’t get many “new” channels when I upgraded to this expensive piece of equipment, as Comcast scrambles (?!?!?!?) digital cable channels. I was dumbfounded why I am paying all this per month for digital cable and cannot set my DVD recorder to record a “free” channel like Noggin. OK, so I will connect it via composite and record with AV-in; I will have to watch as I record, but at least it will work. Nope again – I get a dialog box indicating that it is copy-protected content, and it WON’T RECORD !
    I’ve been all over the web looking for help, and found this bit about entering 1397139 and editing Options:
    Option 2: 35 (enables Divx/Xvid playback) actually 15 worked on mine
    Option 4: ff (enables Vcd and SVCD playback)
    Option 5: ff (enables region free playback (region 0) DVD playback)
    Option 6: ce (enables Insignia brand startup logo on boot)
    Option 6: c0 (enables LG brand startup logo on boot)
    Is there a list anywhere of all the available options choices and what they do ?
    I am sure there is a way to turn off the annoying macrovision check, and get 4:3 upconverted with pillar boxes. Having my RC797T upconvert over component would be prefered as well.
    I want to use this DVD recorder for what I bought it for.
    get this:
    I was fiddling with the Option 6 choice, and I got a ZENITH startup screen, so I tried more codes and one of them DISABLED the options !
    I cannot get back to the options screen.
    entering 1397139 while TV aspect 16:9 no longer accesses this screen !
    I tried unplugging it overnight, and that did not reset it.
    I can still watch Dvix files, so those options must be hardcoded or flashed somehow.
    Does anyone have another way to access the 1397139 Options screen ?!?!?!?
    HELP !
  3. Member Krispy Kritter's Avatar
    Many recorders suffer from the same issues. The number of channels that you can receive/use is dependant upon your cable provider. On a side note, simply upgrading to a DVR supplied by your cable provider for $5-10 a month will solve these issues.
    As to the codes, I don't know.
    Google is your Friend
  1. LC RC797T Hack (0xE0)
    By oscar46324 in forum Newbie / General discussions
    Last Post: 18th Apr 2009, 13:42
  2. 4:3 Playback issue with LG RC797T
    By yumitree in forum DVD & Blu-ray Recorders
    Last Post: 6th Nov 2008, 12:06
  3. Help resetting original Service Tecnician's Menu for LG RC797T
    By corrhead in forum DVD & Blu-ray Recorders
    Last Post: 30th Jun 2008, 22:34
  4. Used PC issues
    By CSULB71 in forum Computer
    Last Post: 16th Dec 2007, 12:00
