I have a Sony DCR-Sr200 Handycam (output is mpeg2 files), my brother-in-law has a Sony HDR-SR (output m2ts files) can I combine these? We both took video at my parents 50th Annv. I thought because we were both shooting with Sony camcorders that I could just read his files...turns out I can't. I have Motionpicture vers 2.0.06.13151 it doesn't recognize m2ts files. Any ideas?
Results 1 to 9 of 9
Combine and make a dvd? or just combine and make mpeg2 files?
combine and make a DVD
You picked the two most difficult formats to edit. I'd have difficulty with that project.
Are you up for heavy lifting?
I'd go at it with Vegas Pro 8 because that is what I know. First you need to pick a SD or HD project format and strategy. Assuming a SD DVD target, I'd transcode each source to Cineform, edit/filter/process in Cineform format, then output to MPeg2 for DVD.
For simple cuts editing, Womble products might work.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I was hoping to do something a bit cheaper...looks like Vegas Pro 8 is about $600.
Depends on the kinds of editing you need to do. Like I said these MPeg2 and MPeg4 formats are the most difficult to deal with so you need to either take it to a pro or commit to learn what it takes.Originally Posted by hsid
There are simple programs that cut on GOPs, there are others that cut finer. Try womble try cyberlink and see if they work for you. Others will suggest other programs. You need to experience this to begin to understand the issues.Recommends: Kiva.org - Loans that change lives.
vs11+ just might do it
I'm using it now and it seems to combine just about everything I throw at it on the timelineAuthor, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
You can convert the .M2TS files to an easier to edit format.
Change the extensions to .MTS and have a look at this guide:
http://forum.videohelp.com/topic346331.html
Probably the only bright spot here, is they should both be TFF field order........
Soopafresh has the right idea. Use his tools to downsample m2ts into the same resolution as the Mpeg-2 camera. That should keep them on similar footings. Of course the colors will not match...........There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
Sony Vegas Pro 11 crashes with Hauppauge HD DVR m2ts files! Help please!
By soccawalka5 in forum EditingReplies: 22Last Post: 18th Mar 2012, 01:53 -
Audio drifting when merging Sony .m2ts files in tsMuxeR
By jaholmes in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Sep 2009, 12:02 -
How to edit Sony m2ts files to burn to blu ray disc.
By tchambers in forum Authoring (Blu-ray)Replies: 23Last Post: 11th Nov 2008, 22:53 -
viewing .m2ts files from SONY HDR-SR11E
By jjapa in forum Software PlayingReplies: 5Last Post: 29th Jun 2008, 00:12
