I was just wondering if it was possible to burn mp3s onto a dvd-r as data and have it be read by a portable cd player? My philips expanium portable cd player can read any data/mp3 cd I throw at it so I just wondered if it was possible?
Results 1 to 9 of 9
No - wrong media.
Regards,
Rob
No offense...
but...
I have not seen one of these in awhile
And no, you can't get a cd burner to burn dvd media either :POriginally a member since 2001, LONG LIVE TARAN's!!!
um, I have a dvd burner.
Try reading my post u elitist.
Even if someone ask a question like that, this is a forum that's supposed to help people and not put them down.
K THNKS
Originally Posted by majax79
I did read your post... you asked if you could play one format of disc on a diff. format disc player, IE: a dvd disc on a cd player
Lighten up
If I get I believe in giving.
I knew it probably wouldn't work but if my cd walkman will play a cd-r I figured perhaps there was some type of way of fooling it to believe that the dvd-r was a cd-r.
Nope, basically a totally diff. laser to read dvd.Originally Posted by majax79
Some standalone dvd players have 2 laser's & lenses to read both cdr & dvdr & some have one lens & 2 laser's to read both through the same lens, but unless it is made to read both, it won't.Originally a member since 2001, LONG LIVE TARAN's!!!
To put it another way:
The burned-in or stamped-in "holes" that make up the digital code in a DVD disk are much smaller than the "holes" in a CD. Therefore, a different wavelength of laser light is needed to read each type of disk.
There are disk drives that have both kinds of lasers for reading the disks, and both kinds of lasers for burning both kinds of disks, but there is no way of "tricking" CD-burning software into thinking that a DVD disk is a CD disk.
The two types of disks are manufactured differently, with code (burned with the appropriate-size "holes") that tells a CD/DVD burner what type of disk it is, and the "dye" in one type of disk cannot be effectively burned by the wrong wavelength of laser, if at all.
Even if you could, there would be no advantage. The physical size of the "holes" would not make the DVD disk hold any more data that a CD disk could, since the two disks are the same physical size.
Thanks so much for the information ebenton.
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 8Last Post: 19th Apr 2012, 15:30 -
Lenco portable dvd player DVP-931 MPEG4 playback problem.
By edh in forum Video ConversionReplies: 5Last Post: 13th Jun 2010, 04:58 -
Portable hdd player determining playback limits
By terramir in forum Portable VideoReplies: 2Last Post: 6th Sep 2009, 22:46 -
audio playback problem on television dvd player
By nathy85 in forum AudioReplies: 4Last Post: 16th Nov 2007, 16:17 -
Portable DVD Player Audio/Video Unsync Problem
By wicious in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2007, 08:14
