hello
I made a DVD folder, containing Video_ts and Audio_ts, ready to be burned to a DVD
But, also, I want to add other folder with some pictures used in the movie, but the burn sofwares only allow me to include ifo, vob and other files that belong to a dvd structure.
Is there any way to add a folder with extra files in the DVD structure?
thans
Claudio
Results 1 to 13 of 13
What tools are you working with? Encoder? Authoring?
Throw us a bone.
dadrab:
-mpeg file edited and encoded with Adobe Premiere Pro built-in encoder
-Authored with Adobe Encore DVD
-Burned (or try to be burned..
wiht Nero, Easy dvd creator, and others)
claudio
I've never used Encore, so I don't know whether it supports slideshow functionality or not, but I suspect it does. Perhaps some of the other folks around will chime in.
I use DVDLabPro to author and adding a slideshow in that is pretty easy, but there's a learning curve. You can add all your pictures in the "Assets Bin" just like you would a a movie or a soundtrack, but that's a PITA. Instead, if you open a new slideshow, one of the icons at the top of the slideshow working window is to add a folder to a slideshow. Click on it and graphics files within the folder you choose are automatically added to the show. You can manipulate from there as to length, sound, etc, etc.
Oh yeah...
It's going to sound like I'm on an anti-Nero campaign (and maybe I am), but I'd use IMGBurn to create the final disc.
But, then:
Is it possible to have another folder in the root disk ?? Video_ts, Audio_Ts and.... "Pictures" or "Files_used" , for example ??
This is just what I want to know
Claudio
You can do that with mkisofs:
--- First, move the DVD-Video folders and the extra ones to a temporary directory
(e.g. "C:\DVDVolume")
--- Secondly, run this command-line:
--- At last, burn "filename.iso" with [s:edcfb62d76]your favorite burnware[/s:edcfb62d76] ImgBurn,mkisofs -v -V volumename -o filename.iso -dvd-video C:/DVDVolume
cdrecord, or PRASSI Ones.
HTH.
Name that folder 'JACKET_P' and you'll be DVD compliant.
You can add any folder you like at the same level as the video_ts folder and burn a compliant disc. Imgburn is the best and easiest option (build mode, select the Video_TS folder, then select the extra folder and burn), but nero can do it as well. It doesn't have to be as complicated as people are making out. You can even use Nero to do it, if you must.
Encore DVD 2.0 will let you include a DVD-ROM folder (under the DISC tab, or file/select dvd-rom folder).
You can then burn a DVD Image file (which will include the specified DVD-ROM folder).
Regards,
George
are the extras, for the PC, or for viewing on the DVD player
for the DVD player use, IDK
but for PC use , just put the folder in the disc root after you choose the video_ts folder, then burn the disc with image burn, or burn as a data disc.
for the most part a DVD player doesn't care if there is extra stuff on the DVD as long as the video_ts folder is there
Just to avoid confusion, if you plan to play it on a DVD Player, you want to avoid burning as a DATA disc -- because the DVD Player does care for the proper placement of the files for your dvd-video (i.e. use DVD-VIDEO mode if your burning software offers a choice between DVD-VIDEO and DVD-DATA).Originally Posted by theewizard
Regards,
George
Audio_TS & Video_TS what they mean exactly?
By Deadmoney in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2011, 11:31 -
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 14:37 -
I don't get any movie.DVD folder (audio_TS & video_TS), help!!!
By dbedolla in forum MacReplies: 1Last Post: 10th Nov 2009, 03:21 -
AUDIO_TS folder
By siluet in forum Newbie / General discussionsReplies: 14Last Post: 10th Oct 2009, 07:00 -
HELP!!. . .DVD Without AUDIO_TS Folder???!!!!
By sniperloc in forum Authoring (DVD)Replies: 13Last Post: 17th Feb 2009, 12:29
