I have a Sony RDR-GX350 and would like to make it ALL REGIONS as I need to watch Region 1 and Region 2 DVDs -please can you tell me how to change it?
Many thanks in advance.
Shinners
Not all players can be hacked and if you know that you need a region free player, then you should be shopping for a region free player and not just hoping a player can be "hacked". In addition, Sony players are known to not be be easily hacked or even hacked at all.
With that said, the palm pilot or service remote hack appears to work for this player:
http://www.novii.tv .
Install novii remote in yours PocketPC or Palm.
Install to (move to) 'novii folder'/Codebases/ file 'DVD_sony_0.pdb'.
Power on your player without a disk (the tray is closed).
Start on yours PocketPC(Palm) the program 'novii remote'.
Select 'DVD_sony_0'. Direct the infra-red port your PocketPC(Palm) on dvd-player.
Press the buttons "1","2","3","4","5".
Your player is multiregion.Google is your Friend
Well obviously??!!!I would have bought a multiregion had I have known I would need it. At the time I didn't and now I do.
It's not our fault you didn't consider this possibility. So it's not your fault either? Hmm... I'd say Krispy Kritter was kind to give you more help than you truly deserve.Originally Posted by Shinners
Sony DVP-SR600H Multiregion Hack Please!!!
By T-Miles in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Aug 2011, 07:21 -
Sony DVD Recorder RDR-GX350 - Region Hack Code Required.
By Teac23 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Sep 2009, 03:19 -
sony rdr hxd 560 hack
By rex diablo in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2007, 12:22 -
Sony RDR HX 725 Region Code Hack question
By bootymeister in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Aug 2007, 11:20 -
multiregion hack
By chrissi34 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jun 2007, 16:59
Statistics
Newest guides
Latest tool updates
New media comments
