hi dear all-knowing videohelp-communtiy,
i'm coming to you with a stupid newbie question...
but i don't know how to search for that on google
i thought to myself "hmm, all new hd dvd/blu-ray/dvd players got this upscaling thing
which basicly just makes the movies look better... so what about upscaling for the pc?"
background:
i'm watching my dvds & dvd-rips on my media center pc connected via dvi to an hd-ready
flat screen. quality is good but i know it could be better, but how?
thank you for your help,
-slim
Good upscaling equipment uses specialist hardware designed to do one job very well. Your PC doesn't have this hardware, nor is it available. The best you can do is maximise your playback screen and hope the player software doesn't make it look too bad.
If you want good quality upscaling, get a good quality DVD player with a decent upscaling chip.
You could use ffdshow filters to get pretty good "upscaling", see http://www.avsforum.com/avs-vb/showthread.php?t=719041
And depending on your TV and how the PC is connected to the TV, it may be irrelevant as the TV may already be upscaling the input to match the TV screens resolution.
Google is your Friend
The DVD is native 720x480 or 720x576.
If your display card is outputting 1366x768, the display card chipset is doing the upscale. All you need to do is select "Full Screen" on the player window.
If you feed the TV at other than native resolution, the TV will rescale to native resolution either up or down.
The quality of upscale depends on your display card chipset and the TV's built in scaler.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
And if you have hardware Video Overlay disabled then the player (or Windows) does the scaling in software.
Right
Thats what I thought too exactly.Originally Posted by edDV
The resolution displayed would match the resolution the PC is already set to.
netbook upscale dvd?
By ieh4f in forum Software PlayingReplies: 2Last Post: 29th Mar 2010, 19:01 -
VHS to DVD+R playback on computer
By rchunah in forum CapturingReplies: 3Last Post: 9th Sep 2009, 10:37 -
How to upscale DVD movie to HD on LG RH387H?
By ergodyne85 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 18th Dec 2008, 01:03 -
Philips vs Pioneer upscale DVD player, which one?
By hanugro in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Dec 2007, 04:08 -
DVD recorder -> playback on computer
By blazejay in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2007, 12:22
