Hello All!
I have a video file that came with an extension of .TP G-Spot v2.70a indicates that it is an MPEG-2 Transport Stream, Mime Type: video/mp2t but gives no other info on it (with 265 codecs loaded). I know the file is an HDTV capture (1920x1080i & AC3). It will play with Media Player Classic (choppy) and with VLC, which plays perfectly smooth.
What codec is appropriate for it and should it in fact have an .MPG extension?
Thanks much!
--- DeathStalker77
Edit: After my post was moved to this forum, I see that there is a sticky on .TP files, so hopefully that will answer my questions. Thanks!!!![]()
Thread: MPEG-2 Transport Stream ...
No, it should be named tp or ts. You can convert it to a mpg with hdtvtompeg2.
I would use ffdshow, haali media splitter and play with Media Player Classic(You might have to disable the internal mpeg2 decoder in mpc).
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
MPEG transport stream
By mkrtich.nazaryan in forum Video StreamingReplies: 4Last Post: 10th Jan 2011, 14:29 -
Is the mpeg-2 transport stream HD or SD video?
By coody in forum Video StreamingReplies: 4Last Post: 27th Aug 2010, 12:33 -
By avsubvert in forum Video ConversionReplies: 2Last Post: 7th Aug 2009, 11:39 -
MPEG Transport Stream Format
By Hoggle in forum ProgrammingReplies: 3Last Post: 26th May 2007, 20:03
Statistics
Newest guides
Latest tool updates
New media comments
