    Aug 2003
    Australia
    Hi all, my dvd writer is all of a sudden not reading/writing dvd's??
    I have tried various CD's and they all work fine, the drive reads them instantly, but when I insert a dvd, it tries to read it then just stops. No matter whether it's a commercial dvd movie or a dvd data disc which I have made.
    When I go to "My Computer", it asks me to insert a disc when there is already one in there.
    I don't think the writer is broken as it still reads cd's ok.
    Can someone please help, the writer is an LG (not sure what model, how do I find out?) and is about 6 years old.
    Very tempted to buy another writer but there must be a solution to this.
    In anticipation.
    It's not a Black and White world, to be alive the colours must swirl.
    And I believe that maybe today, we would all get to appreciate.... The Beauty of Gray.
    - Ed Kowalcyk (LIVE) -
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    CD burning/reading uses a different laser, so CDs may work, but DVDs fail if the DVD laser is dead. You could try cleaning the laser lens, but both lasers use the same lens, so not likely the problem. I would consider replacing the drive.
  3. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Try to boot from a DVD.............
    *** Now that you have read me, do some other things. ***
    Aug 2003
    Australia
    Boot from a DVD, what does that mean?? Sorry??
  5. Member classfour's Avatar
    The Heartland, United States
    I suspect your DVD laser has crapped out. You'll hear it on this forum plenty: With DVD Burners being so cheap, everybody should have no problem replacing a problem drive. I'd recommend replacing a two year old drive that's bad - a six year old: In a heartbeat.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  6. Yep, DVD drive is likely bad. I'm guessing you likely burn and read a lot more DVD's than you did CD's, but even so, there's separate mechanisms in there for each media. Spend the $30-40 and get a new and improved writer over that like 4x-8x that you probably have now. I saw a Pioneer 18x at Fry's in the paper today for something like $44 with a $20 Pioneer rebate. $24 for an 18X writer is pretty decent at $44, not to mention $24.
    May 2003
    You can find lite on 20x burners at the link below for $24.99 new.
    www.tigerdirect.com
  8. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    www.tigerdirect.com
    The OP is in Australia so I don't think Fry's or Tiger Direct will help her.
