I recently got an AVI file in HD, so the quality is awesome. The problem is that it has no subs. I want to keep the file, and I think I can get the subs from a fansub group. My question is what kind of programs are available for the mac that can hardsub for an AVI file? What kind of sub format will I need? I can probably watch it with soft subs with VLC or something, but I want to be able to hardsub it to AVI then convert it to MP4 for iTunes and my iPod.
Thanks for your time.
Results 1 to 18 of 18
Thread: How do I hardsub an AVI file?
On the mac, ffmpegx can do this for you. Your problems will be minimized if you can find subs in .srt format. You might be able to hardsub while converting to MP4 (but I'm not certain of this with ffmpegx); if so, you can avoid an extra encoding step (and its associated degradation). If not, you can hardsub to another (high bitrate) avi, and then use that to encode your MP4.
Thanks to Perian, that is now possible with ffmpegX and the iPod preset. The Decode with QuickTime setting renders a .srt subtitle onto the video while encoding. It used to require Decode with mplayer for mencoder presets, but now we have more options.Originally Posted by tomlee59
Just make sure of matching names, e.g. movie4598.avi and movie4598.srt, so that Perian finds the subtitle file.
Thanks, Case. As usual, you're the one with the answers!
The same thing applies. If the .srt is named right, and you have Perian installed (with Load External Subtitles activated in the Prefs Pane) and you force QuickTime decoding in Advanced settings, then you'll get hard subs.Originally Posted by VidHunter
Viddyup also does subs. It will let you preview the timing so you don't waste your time with the complete encoding only to discover it's off later.
Another good tool is Jubler which will let you alter the timing of one or all the subtitles. I've occasionally found subs that are off by, let's say, 2 seconds and Jubler lets me shift all of them the same amount. Jubler will also open quite a number of different subtitle formats and let you save them as ".srt" type (which ffmpegX and Viddyup like).
Hope this helps.
Jubler is indeed a must-have tool for anyone trying to solve the all-too-common sub sync problem. Thanks, rumplestiltskin.Originally Posted by rumplestiltskin
Thanks for all the suggestions.
I will definitely try the force quicktime decoding with visualhub.
Case, you saved me from my video troubles again.
P.S: I need to put the .srt in the same file as the video for it to work, right?
The .srt and the .avi should be in the same folder, yes.Originally Posted by VidHunter
With Perian installed, you can export .avi with subtitles to .mp4 or h264 for iPhone, iPod and AppleTV using the QuickTime Pro..Or any other format QuickTime supports..
"IE 7 and Vista remind me of the old definition of a giraffe: it's a horse designed by a committee."
Just an update, when I try to use the "force quicktime encoding", I get a white screen with no sound.
When I leave the "force quicktime encoding" off, it works like charm with subs and everything.
I guess I just have to put the sub file in the same place as the video for visualhub to pick it up. Oh well, as long as it works, Im not gonna question how it works. :P
*Update* If all else fails, I can use submerge to hardsub an mp4 file right? Or does submerge only change softsubs?
Don't know how long it's taking you with your programs but I was tryin to save avi files with subs for play on my PS3 and found a PC program (which I run on my intel Mac with Crossover) called AVIAddXSubs which converts the 2 files (avi & srt) into a playable DIVX movie in about 2 minutes. I tried everything else I could find for Mac and nothing comes close. It might be worth it to convert to a DIVX first with that program then find a solution to convert for the iPod.
AVIAddXSubs adds a bitmap subtitle stream, it doesn't hardsub which is what the OP wants for his iPod.
And say I wouldnt want it to be a mp4 file.. say I'd just want to keep it .avi, but with hardsubs... What program could i use for that ? Cause all i can get it to do is work as a quicktime file.. I want to be able to save it with hardsubs so I can stream it on the Xbox360. It doesn't use the subtitles like Quicktime does.. Xbox won't see the subs if there just there in the folder, n not actually hardsubbed...
Helllpppp!!
If you had Windows, you could use AVI ReComp. It's actually sort of a "ringmaster" program, it directs the actions of several other programs to spit out a very nicely hardsubbed AVI.
and... what if i'd have a Mac n no Windows?
would that make hardsubbing impossible or... ??
Hardsub for a MPeg2 HD file (1440*1080)
By emivar27 in forum Newbie / General discussionsReplies: 9Last Post: 19th May 2011, 02:09 -
Hardsub AVI movies
By Jacks in forum SubtitleReplies: 7Last Post: 24th Jul 2010, 07:23 -
Hardsub embedded mkv file?
By j03uen in forum SubtitleReplies: 4Last Post: 19th Apr 2010, 04:09 -
How can I extract hardsub from MKV. file
By Rippl in forum SubtitleReplies: 12Last Post: 7th May 2009, 14:00 -
How do you hardsub .ass files into a .mp4 file?
By kevinayP in forum SubtitleReplies: 1Last Post: 26th Jan 2009, 08:27
