I bought a Toshiba D-R400 and it has pass-thru feature that allows you to pass the signal from a satelite reciever thru the DVDR deck to the TV when the DVDR is tuned-off. I can only get to work with the composite video cable as input and output. The manual is vague on this feature. I called Toshiba's customer service and they told me it should work with the S-video jacks but I am unable to get to work with the S-video jacks. The DVDR has a menu item to select whether the DVDR input jack is set to video or S-video.
Anyone know if it works with the S-video jacks on the DVDR?
Thread: Toshiba D-R400 Pass-thru
I, too, was only able to get the composite to work, though I did not spend much time trying the other inputs/outputs. The one time I tried the S-Video, pass-thru did not seem to work, but I may not have had it setup right.
Pass-thru on the composites worked great. I don't have mine hooked up at the moment or I would try again.
Good luck!Bron
I just got the D-R400 and am very happy with it.Originally Posted by Bron
I've successfully set up my satellite receiver to use the pass-thru via composite in and out. The manual does state that this is the only way pass-thru will work. It works fine while the D-R400 is off, however the pass-thru is instantly disconnected the moment the D-R400 is turned on. Is this normal?
Yes, that's exactly how it's supposed to work. Pass-thru is active only when off - that's the idea.
When it's on, you control the output selections.Bron
Thanks for your response. Sorry if there was some ambiguity in my query. My concern is that with the unit turned on, keeping the composite output selected, no signal goes through - TV is blank. However, selecting component or HDMI lets the signal through.Originally Posted by Bron
Using the pass-through function for DV with Toshiba RD-XS35
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 0Last Post: 26th Jan 2008, 06:30 -
PAL Disc on Toshiba D-R400 and Samsung LNT5265F
By super_pipo in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Jan 2008, 11:40 -
Toshiba D-R400 QUestion on Playing Back AVIs
By shaggy2002 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th Nov 2007, 14:09 -
Toshoba d-r400, anyone have this?...
By rubberman in forum DVD & Blu-ray RecordersReplies: 2Last Post: 23rd Oct 2007, 17:35 -
Toshiba D-R400 DVD Recorder - Is it PAL enabled?
By JEG in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Aug 2007, 16:27
