Hello,
I'm seeing a bunch of errors from mencoder when trying to create a copy of the file (just trying to trim it down). Here is the command line I'm using:
and the output (truncated):Code:mencoder file.mpg -ovc copy -oac copy -of mpeg -endpos 00:01:00 -o test.mpg
The file is from a VHS->TiVo dub. Also note the strange frame size (480x480), though that's normal for tivo video. My question is, are those errors something I need to worry about, or are they OK?Code:MEncoder 1.0rc2-4.2.1 (C) 2000-2007 MPlayer Team CPU: Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz (Family: 6, Model: 15, Stepping: 10) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled with runtime CPU detection. success: format: 0 data: 0x0 - 0xe9b89292 MPEG-PS file format detected. VIDEO: MPEG2 480x480 (aspect 2) 29.970 fps 8700.0 kbps (1087.5 kbyte/s) [V] filefmt:2 fourcc:0x10000002 size:480x480 fps:29.97 ftime:=0.0334 ========================================================================== Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 48000 Hz, 2 ch, s16le, 192.0 kbit/12.50% (ratio: 24000->192000) Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3) ========================================================================== PACKET SIZE: 2048 bytes, deltascr: 245760 videocodec: framecopy (480x480 24bpp fourcc=10000002) audiocodec: framecopy (format=50 chans=2 rate=48000 bits=16 B/s=24000 sample-1) Limiting audio preload to 0.4s. Increasing audio density to 4. Writing header... INITV: 0.200, 0.167, fps: 29.970 Pos: 0.0s 1f ( 0%) 0.00fps Trem: 0min 0mb A-V:0.000 [0:0] Pos: 0.1s 2f ( 0%) 0.00fps Trem: 0min 0mb A-V:0.003 [0:0] Pos: 0.1s 3f ( 0%) 0.00fps Trem: 0min 0mb A-V:0.007 [0:0] (...) BUFFER UNDEFLOW at stream 0, raising muxrate to 1980 kb/s, delta_scr: 223418 BUFFER UNDEFLOW at stream 1, raising muxrate to 2178 kb/s, delta_scr: 203107 BUFFER UNDEFLOW at stream 0, raising muxrate to 2395 kb/s, delta_scr: 184643 BUFFER UNDEFLOW at stream 0, raising muxrate to 2635 kb/s, delta_scr: 167857 BUFFER UNDEFLOW at stream 1, raising muxrate to 2898 kb/s, delta_scr: 152597 BUFFER UNDEFLOW at stream 0, raising muxrate to 3188 kb/s, delta_scr: 138725 ERROR: scr 1.544, dts 0.000, pts 1.433 ERROR: scr 1.668, dts 1.501, pts 1.601 BUFFER UNDEFLOW at stream 0, raising muxrate to 3507 kb/s, delta_scr: 126114 ERROR: scr 1.673, dts 0.000, pts 1.505 ERROR: scr 1.855, dts 0.000, pts 1.601 ERROR: scr 1.860, dts 1.601, pts 1.702 (...) Writing index... Overhead: 1.418% (653432 / 46075784) Writing header... Video stream: 5988.216 kbit/s (748527 B/s) size: 44931556 bytes 60.027 secs 1802 frames Audio stream: 192.000 kbit/s (24000 B/s) size: 1440000 bytes 60.000 secs
Thanks.
Those errors are multiplexed errors. Common with TiVo files. You'll need to use -mpegopts
The errors you displayed will most likely cause playback and sync problems. Buffer underflows are bad.MPEG muxer (-mpegopts)
The MPEG muxer can generate 5 types of streams, each of which has reasonable default parameters that the user can override. Generally, when generating MPEG files, it is advisable to
disable MEncoder’s frame-skip code (see -noskip, -mc as well as the harddup and softskip video filters).
EXAMPLE:
format=mpeg2:tsaf:vbitrate=8000
format=<mpeg1 | mpeg2 | xvcd | xsvcd | dvd>
stream format (default: mpeg2)
size=<up to 65535>
Pack size in bytes, do not change unless you know exactly what you are doing (default: 204
muxrate=<int>
Nominal muxrate in kbit/s used in the pack headers (default: 1800 kb/s). Will be updated as necessary in the case of ’format=mpeg1’ or ’mpeg2’.
tsaf
Sets timestamps on all frames, if possible.
init_vpts=<100-700>
initial video pts, in milliseconds (default: 200)
init_apts=<100-700>
initial audio pts, in milliseconds (default: 200)
vdelay=<1-32760>
Initial video delay time, in milliseconds (default: 0), use it if you want to delay video with respect to audio.
drop
When used with init_adelay the muxer drops the part of audio that was anticipated.
vwidth, vheight=<1-4095>
Set the video width and height when video is MPEG-1/2.
vpswidth, vpsheight=<1-4095>
Set pan and scan video width and height when video is MPEG-2.
vaspect=<1 | 4/3 | 16/9 | 221/100>
Sets the display aspect ratio for MPEG-2 video. Do not use it on MPEG-1 or the resulting aspect ratio will be completely wrong.
vbitrate=<int>
Sets the video bitrate in kbit/s for MPEG-1/2 video.
vframerate=<24000/1001 | 24 | 25 | 30000/1001 | 30 | 50 | 60000/1001 | 60 >
Sets the framerate for MPEG-1/2 video. This option will be ignored if used with the telecine option.
telecine
Enables 3:2 pulldown soft telecine mode: The muxer will make the video stream look like it was encoded at 30000/1001 or 30 fps. It only works with MPEG-2 video when the output
framerate, converted with -ofps, is either 24000/1001 or 24 fps. Any other framerate is incompatible with this option.
film2pal
Enables FILM to PAL and NTSC to PAL soft telecine mode: The muxer will make the video stream look like it was encoded at 25 fps. It only works with MPEG-2 video when the output
Of the above options, you'll need to tinker with format, vbitrate. tsaf, and muxrate.
Maybe
mencoder file.mpg -ovc copy -oac copy -of mpeg -mpegopts format=dvd:tsaf -endpos 00:01:00 -o test.mpg
Would be a good starting point.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
Thanks for the input. I have adjusted the options, and resolved the errors, but I cannot find any information about what the impact of those options are. I'm now using:
The bitrate comes from the bitrate that Tivo uses when recording in Best quality. I just kept bumping the muxrate higher until it didn't complain anymore, but what is the impact of doing that?Code:mencoder file.mpg -ovc copy -oac copy -of mpeg -endpos 00:01:00 -o test.mpg -mpegopts tsaf:vbitrate=5800:muxrate=7500 -noskip -mc 0
CRC Errors when copying to HD
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2009, 07:24 -
Using mencoder to crop and convert .avi to .flv - errors
By brandox in forum Video ConversionReplies: 0Last Post: 26th Jan 2009, 11:09 -
Copying a DVD-R with errors
By samijubal in forum DVD RippingReplies: 7Last Post: 17th Oct 2004, 18:01 -
mencoder bus errors and segfaults?
By brysongilbert in forum ffmpegX general discussionReplies: 2Last Post: 15th Oct 2004, 15:25 -
Help read errors while copying
By kenmo in forum DVD RippingReplies: 5Last Post: 22nd Sep 2003, 20:32
Newest guides
Latest tool updates
New media comments
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
