For months I've been searching for a good QT H264 converter.
I would love to achieve the quality of the Apple trailers website, but they probably use sources that most of us don’t have/use – something like D5 tapes.
Basically I’m looking for a professional software that enables to encode AVI/MOV (DV codec or uncomp.) files to 3 or 4 different profiles (different bitrates, image size , etc).
I’m using at the moment Sorenson Squeeze 4.5.7 – the best FLV On2 encoder for me – to transcode to MP4 (with h.264 codec) than opening the MP4 in QT Pro and converting to MOV by “Save as a self-contained movie” without making any compression, it simply changes something in the log of the file by renaming from .MP4 to .MOV.
The quality of the files is not bad.. but I know that is possible to get better results.. I just don’t know how.
I was using Apple Compressor for while – the results are a bit better that Sorenson Squeeze but takes too long to encode.
Any advice for a different method MUCH appreciated.
Results 1 to 15 of 15
Thread: The best Quicktime H264 encoder?
MeGui,
AutoMKV,
Automen,
Avanti: http://forum.videohelp.com/topic343287.html#1793545I love it when a plan comes together!
Ricardo Santos
Thanks for the help.
I checked the solutions that you adviced one by one and none seems to be a good update from the solution that I'm using at the moment.
Basicly what I'm trying to find is a good software and workflow that enables to:
1) Input AVI / MOV
2) Encodes/Transcodes Quicktime H.264
3) Batch mode + different profiles (bitrates, video size, etc)
4) Achieve good Quicktime H.264 output video files
Thanks!
You want to make serious speed improvements, then upgrade your CPU. The old Athlon 1800XP is getting pretty long in the tooth. Quality takes time. If you have a quality solution that is too slow, put more grunt behind it.
every single program i suggested can convert to MP4/h264 that can be opened or streamed with quicktime player or latest flash player.Originally Posted by totalfreedomI love it when a plan comes together!
Ricardo Santos
guns1inger - we are right about the the CPU but my problem is quality and not speed.
ricardouk - thanks for the names of the softwares. I did test them and the quality of the mpg4 h.264 is lower than the one produced by Squeeze or Compressor
Does anyone know a solution/software that can improve my results apart from Apple Compressor or Sorenson Squeeze.
When I say improve my results = better video quality when encoding/trancoding to quicktime h.264.
So if anyone could give names of softwares that they used for encoding in this format and that have achieve great quality videos please share with us.
Thanks!
Anyone?
i think you havent tested the tools properly....
megui and automkv are top quality h264 "encoders", it beats sorenson squeeze.
but if you stil think that they're not good you can try mpeg streamclip, instal quicktime alternative to get the codecs.
you must be be doing something wrong, have a look in the comments on each program and compare it to quicktime pro, just in case you dont belive me.I love it when a plan comes together!
Ricardo Santos
Totalfreedom,
What do you want to use the videos for? Ipod? Streaming? Home network?
After long testing and retesting I have gotten the best results with TMPGEnc 4.0 Express. I have used:
Nero - good
Handbrake very good (only from dvd)
QT Pro - OK
Videora - ok not spectacular
TMPGEnc 4.0 Express - Spactacular!
As I said after long testing. There are more options, filters, bells and whistles in TMPGEnc than most will want to fool around with. However, the quality is better for the bitrate than any other - after the pain of finding the right settings. Don't use the defaults.
Squeeze 5 includes 3 H.264 codecs. The main concept is by far the best one and better than Apple's.
Why do you need it in the MOV wrapper? QuickTime web Active X will play MP4 files.Take your skills to the next level @
http://webvideotechniques.com
Does Squeeze 5 uses Main Concept Encoder?
Squeeze 5 offers Main concept, Sorenson AVC, and Apple AVC with MP4. Unfortunately, they still dont have MOV wrapper with any of them.
The main concept encoder is great, but it takes quite a while to encode multipass. On my P4 3.2Ghz it was reporting about 10 minutes per minute of video.Take your skills to the next level @
H264 is better than FLV On2 compressor, QT pro can do h264 compression, but it is very slow. I think you can try total video converter, try profile h264 AVI, or AVC h264 mp4. At present, h264 is the most powerful alogrithm for video compression, and only h264 AVI uses the toppest level of compression.
I don't know, maybe this is a dumb question, but what is the destination/venue for this? iPod? Embeded in a Web page? Private distribution? (dvd/cd)
hi
good thread
what's the advantage of Tmpgenc 4.0 Xpress over Sorensen Squeeze 5 MP4 please?
thanks
Ricric
DivX H264 Encoder
By Anakin in forum Video ConversionReplies: 1Last Post: 21st Jan 2012, 14:04 -
transcoding from avi h264 to Quicktime H264
By muffinman123 in forum Video ConversionReplies: 1Last Post: 24th Sep 2011, 05:56 -
Uncompressed AVI to Quicktime H264
By Simmons in forum Video ConversionReplies: 7Last Post: 3rd Aug 2011, 19:15 -
I'm looking for a good MP4-2/H264 video encoder which should NOT be based o
By clipperyoungamerica in forum Video ConversionReplies: 7Last Post: 19th Mar 2010, 16:54 -
How to properly configure Mainconcept h264 encoder
By bidomo in forum DVD RippingReplies: 0Last Post: 29th Jul 2007, 20:29
