VideoHelp.com Forum
    I have DVD fab Platinum and am trialling its features.
    I was experimenting with a TV series from a DVD9 I own and tried to extract a few episodes and compose a DVD.
    I used DVD Fab Platinum to extract what I thought were the last three episodes then used Nero Vision to compose a DVD with a menu for the three episodes.
    When I burnt the trial DVD the menu worked OK and the first two episodes played with sound but the third episode played OK but had no sound.
    Can anyone offer any advice on why the third episode had no sound. (The last episode from the DVD9)
    Thanks all
    Do you hear the audio in the third clip after you extracted it with videoredo? play with for example mpc or vlc.
    Not sure what you are asking about sound of the third clip.
    Can I check the clips for sound within VideoRedo Plus or do I have to use an app.
    Are mpc and Vlc two suitable apps.
    Thank you
  1. Replies: 8
    Last Post: 3rd Jan 2010, 23:49
  2. DVD Fab Platinum Frequently Fails, But DVD Fab HD Works. Why ?
    By MacPCConsultants in forum DVD Ripping
    Last Post: 4th Mar 2008, 03:39
  3. DVD Fab Platinum to HD
    By mblanco2000 in forum DVD Ripping
    Last Post: 2nd Mar 2008, 15:50
  4. DVD Fab Platinum 3.08.6 & Vista
    By ochsfamily in forum Software Playing
    Last Post: 19th Dec 2007, 12:10
  5. Purchasing DVD Fab HD or Platinum ?
    Last Post: 1st Dec 2007, 23:21
