What encoders besides MainEncoder and TMPGenc are compatible with Vista 64bit? I tried CCE and it will not run. The Main and Tmpgenc both work but I was wondering if there was a better encoder that would work with this version of windows. The main encoder works quickly and takes advantage of all 4 cores.
Thread: Vista 64bit compatible encoder
A MPEG-2 encoder? Not any I am aware of that can use 4 cores and a 64 bit OS natively, but Canopus ProCoder can use multiple cores and maybe HC can. Most MPEG-2 encoders available are listed here: http://www.videohelp.com/tools/secti...coders-mpg-dvd
But others may have some ideas.
You can run a cople of sessions TMPGEnc and render in parallel. I use to different disk drives for this.
Using Vista 64bit..no video in the final MPEG...
By rickb526 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 26th Sep 2009, 17:18 -
Xvid and Vista 64bit
By adalect in forum Video ConversionReplies: 11Last Post: 1st Aug 2009, 07:44 -
Capture Card for Vista Ultimate 64bit
By cgcarter in forum CapturingReplies: 1Last Post: 5th Dec 2008, 11:24 -
Windows Vista - 32bit or 64bit?
By HatchetMan in forum ComputerReplies: 29Last Post: 12th Jan 2008, 00:24 -
Is Cinema Craft Encoder compatible with Windows Vista?
By cormor in forum Newbie / General discussionsReplies: 8Last Post: 8th Aug 2007, 14:51
Statistics
Newest guides
Latest tool updates
New media comments
