VideoHelp.com Forum
  1. Member PuzZLeR's Avatar
    Hi again.
    Long story, but looking to remux a few .mp4s of mine that contain valid H.264 video streams, and valid AAC-LC audio streams. No frame-rate changes, audio delays, PAR changes - just mux one video and one audio stream into one .mp4.
    Of course, the combo of YAMB and mp4box will do just that.
    However, I keep hearing stories of how these muxers don't produce compliant .mp4 files. Avidemux, mp4box with sync, aspect ratios, etc, etc, just to name a few.
    I figure what I want to do is simple, and so far in my testing with YAMB/mp4box, everything works just fine, even in QuickTime, so I can assume all's well.
    But I don't want problems down the road. Is there anything I should know about mp4box that could create bad files?
    Thanks for reading.
    Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
  2. Banned
    nic.dnsalias.com says:
    27.09.06
    NicMP4Mux for iPod v1.2 & iTunes 7.0
    Download:
    NicMP4Box.zip
    Details:
    An awful hack to add the required uuid atom that an MP4 file needs before being accepting by iTunes 7.0 when using H264 files with a width of 640 pixels.
  3. Member PuzZLeR's Avatar
    Thanks for the reply. Yes, Nicmp4box is another one I heard bad stories about. However, my files are in High Profile H.264, certainly not for current iPods, so Nic's hack isn't applicable to me anyway.
    But I heard horror stories even about mp4box, without the hack - something to do with bad headers, or audio delay issues, etc.
    I don't care for any other features other than just muxing a raw H.264 stream with an AAC one. Is there a no-nonsense muxer for this, or will mp4box be enough?
    Maybe I should just use MKV instead...
  4. Banned
    There is a certain mp4creator.exe @ http://ffdshow.faireal.net/mirror/mpeg4iptools/
    A third option would be mp4muxer (from Ateme),
    but it is "illegalware" nowadays
  1. Joining files with My MP4Box GUI
    By Michael33 in forum Video Conversion
    Last Post: 14th Apr 2010, 14:12
  2. Replies: 1
    Last Post: 15th Feb 2010, 05:02
  3. How To Produce High Quality WMV from AVI / DVD Files?
    By devilcoelhodog in forum Video Conversion
    Last Post: 24th Jan 2010, 21:13
  4. Replies: 4
    Last Post: 11th Jun 2009, 13:23
  5. ffmpegX doesn't produce usable files from FLV
    By mdulude in forum ffmpegX general discussion
    Last Post: 15th Nov 2008, 05:43
