I bought a DVD R85 recorder (used) back in 2005. It had an problem with recognizing disks, & it went back for repair. I believe it's the infamous Philips R/W head issue.
Ever since then, it's been working pretty well.
I tried some recording on Memorex 16x DVD+R discs, but it didn't work. The firmware is ff13e.
I found a post at:
http://forum.videohelp.com/topic321829.html
I followed the links for DVD R85/17 (USA model?) & downloaded the ff16k firmware:
I went through the process of upgrading the firmware
http://www.p4c.philips.com/cgi-bin/d...=Link_Software
I burned a CD using "Nero Burning ROM". The R85 didn't take the disk. Then, I had to delete the CPRIGHT.txt file..it took the disk (as per the FAQ, some customers found this was the trick).
The R85 upgraded the firmware to ff16k. However, it won't burn the 16x Memorex DVD+R disk (it has the white coating for "writing"). Specifically, after 5 secs of recording the image just "freezes". No recording shows up in the disk menu.
[ before the upgrade it would record for 2 min, 10 min, etc..but nothing would appear in the disk menu ]
?? What's going on?
I have another DVD recorder, the Philips HDRW 720. A 16x Memorex disk records fine there, & it will play on the DVD R85.
Is the DVD R85 just too old (circa 2003), & Philips doesn't have an upgrade to use the 16x disks?
Results 1 to 1 of 1
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Jul 2007, 00:40 -
JVC DR-M10S won't record on 16X DVD-R's. Firmware update?
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th Mar 2006, 15:00 -
Memorex 16x DVD-R not compatible with Pioneer 531 dvd record
By hayabusa in forum MediaReplies: 3Last Post: 22nd Nov 2005, 12:02 -
The new Sony 16x DVD burner vs. Memorex 16x vs. Pioneer 16x
By kethnaab in forum DVD & Blu-ray WritersReplies: 15Last Post: 28th Oct 2004, 16:06 -
Does using a 16X DVD-ROM = 16X ripping?
By vice86 in forum Newbie / General discussionsReplies: 12Last Post: 24th Jan 2004, 22:48
