Hi, I've installed SP1 RTM and the program won't load anymore. It displays the splash screen then nothing. I've reinstalled the app but that makes no difference. I'm using the latest version.
Results 1 to 9 of 9
Thread: Doesn't work with Vista SP1
Running as admin? Did you install in other than "program files"?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Yeah in admin and installed in program files. Worked fine before the service pack.
Nothing else installed on here either.
You might try a reinstall somewhere other than program files.
Dwight
- Herm Albright
I uninstalled then reinstalled to program files and now it works. Letting the uninstaller run Repair isn't good enough it seems.
8)
Cool, glad it worked.
Dwight
- Herm Albright
Yeah that happen to me too whe I install and after a put my serial number I get my registration code I click register and nothing can somebody tell me wha I need to do please
Are you running as Administrator and have it installed in a folder other than program files as per:
http://forum.videohelp.com/topic324278.html#1776530SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I had the same problem after installing SP1. I also tried the repair (which didn't work). However after uninstalling and reinstalling (getting a new machine code) it worked fine.
-Jay
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Canopos ADVC100 doesn't work with Vista 64?
By something random in forum CapturingReplies: 4Last Post: 23rd Oct 2009, 18:33 -
Windows Vista XP 64 bit Oh, my. Printer doesn't work!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2009, 23:27 -
MSADPCM doesn't work with Vista Home 32 bit
By programm in forum Video ConversionReplies: 1Last Post: 6th Mar 2009, 10:48 -
The Sims 2 Doesn't Work On Vista?
By Nitro89 in forum ComputerReplies: 5Last Post: 19th Nov 2008, 04:09
