VideoHelp.com Forum
Results 1 to 10 of 10
    I don't know if this is the right place but here is my question:
    I'm looking for a (standalone) multimedia hard disk.
    Some demands:
    - needs to be connected directly to a tv-set to play the movies without a PC
    - has to play most commom formats: xvid, divx (...6)
    - play subtitles (srt)
    - >= 500 GB
    Some harddisk is found are (I can buy these localy):
    - LACIE Multimedia harde schijf Silverscreen 500 GB USB 2.0
    - LACIE Harde schijf multimedia LaCinema Premier 500 GB USB 2.0
    - STOREX CLUB MPiX-355 500 GB USB 2.0
    - IOMEGA Externe harde schijf Screenplay 500 GB USB 2.0
    Does anyone know these or have any suggestion, remarks?
  2. I don't know what you mean when you write "must play subtitles/xvid" because this, is software/decoder related, not hard disc related.
    For the average customer, the best brands for a hdd are (in the order):
    western digital, seagate, maxtor, iomega, lacie
    If it's external you should consider one that has a firewire 400 and/or 800 port which is better indeed than USB. (stability/reliability)
    I think something went wrong with my first post. It is missing some text.
    What I also wrote was:
    It has to be a hd that can be connected directly to a TV set to play the movies, music,...
    So the hd must play the most common file-types
    Hello,
    Look at this product.
    http://www.mvixusa.com/
    Have 2 of them and they work great!
    I'm sorry didn't post the model MV 5000u, they two other models also, the ones I have are the MV 5000u
  6. is it Fat32 i.e short and inscrutable file names? That is the failing of most of these things.. plus not really recognizing large hard drives. Might want to try rhapsody or xbmc or really best, an old computer with silent fans and silent this and that. What about a cheap laptop with tv out? or an Lcd with vga in..
    The electronic components of the power part adopted a lot of Rubycons.
    Or http://www.tvixbox.com/ They claim to support NTFS.
  8. Member blinky88's Avatar
    I have just bought a MediaGate-35 with HHD (18months old on E-bay) it does play most formats directly into the TV. I have not received the unit yet, however, I am expecting to get it tomorrow. It is a cheap unit compared to others, from research, almost all the reports are extremely good.
    Please report back your findings!
  10. Frys keeps running this for $99 Klegg multimedia player.
    http://shop2.outpost.com/product/539...H:MAIN_RSLT_PG
    I use a 3 buffalo link theaters but my pal wanted a similiar system so we bought 2 of these devices and it does just about everything. You can play media from your PCS with SMBs, plus you can install a sata hard drive, they can also be used as NDAS devices. They play a wide range of media files plus it will play DVD ISO files with menus and all.
  1. Samsung SMT-C7140 harddisk access
    By Ennio in forum DVD & Blu-ray Recorders
    Last Post: 9th Feb 2012, 03:25
  2. Rescue JVC DR-MH20SE harddisk
    By Anamon in forum DVD & Blu-ray Recorders
    Last Post: 21st Aug 2010, 16:29
  3. Replies: 0
    Last Post: 20th Jun 2009, 17:19
  4. western digital 2TB Harddisk-WD20EADS new on market
    By deejay.2001 in forum Computer
    Last Post: 7th Dec 2008, 16:27
  5. Panasonic E95H Harddisk unformat
    By Flyrider in forum DVD & Blu-ray Recorders
    Last Post: 1st Sep 2008, 17:46
