VideoHelp.com Forum
    hey guys
    some querry about deshaker filter
    i want to stabilize my video (mp4) but everytime i output the video the results were a lot of pin images on the output screen. pls need help..pls need specific step by step process
  2. Mod Neophyte Super Moderator redwudz's Avatar
    That sounds like the results from the first pass that sets up the 'deshaking'. It should make another pass to use the information from that first pass.
    From one site: http://www.guthspot.se/video/deshaker.htm
    During Pass 1 the filter tries to find the panning, rotation and zoom that, when applied to the current image, makes it look like the previous image (almost). It does this by taking blocks of pixels in the two images and finding the shift that makes them match as good as possible. First, to find the "big" motion, the images are reduced a lot in scale and the initial shift is calculated from the whole (scale-reduced) images. This shift is then fintuned in a scale twice as big and with four times as many blocks, and so on. Finally we have the block shifts (or motion vectors) in the full image. The filter then finds the best values for panning, rotation and zoom based on these motion vectors and those values are written to the log file.
    At the start of Pass 2 the values in the log file are read and optimal camera motion is calculated based on the smoothness settings. The filter then transforms each image of the video clip according to this motion.
    Or a bit more complete guide: http://www.sundancemediagroup.com/ar...aker_guide.htm
    Note: Both references may not be to the 'deshaker' filter you are using, but there should be enough info between the two.
    tnx for the tip
    hope it works for me.
    tnx a lot dude it works well for me now.this forum is great!!
    Hi,
    I tested deshaker on a clip of my shoots and it work really good. very much stable
    but when i apply the same setting to a weding of my friend. there start the problem.
    video seems keep rotating left right a bit. and even got shaky even tough source movie is stable.
    i want to know what happen. because my shaky source clip become stable in my test.
    Tin
    now i know. DeShaker have problem with Scene changes, and Panning.
  1. Virtualdub with Deshaker problem
    By snafubaby in forum Newbie / General discussions
    Last Post: 20th Aug 2011, 09:39
  2. Problem when using Deshaker Virtualdub filter
    Last Post: 4th Jul 2011, 00:41
  3. Deshaker (Gunnar) Problem - Really need help from an expert.....
    By JayBTV in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Aug 2010, 09:20
  4. Color problem after using deshaker
    By lgh529 in forum Editing
    Last Post: 9th Aug 2009, 19:25
  5. Virtualdub Deshaker filter has ceased to work
    By MrPerson in forum Editing
    Last Post: 29th Apr 2009, 00:04
