    Feb 2008
    Canada
    Hi every body i really nned your help i ve received somme VCR tapes from Europe (backhome) and can't play them i got an LG LVC 837 and i was told that i can find help here so pleaseeeeeeeee if anyone can help i will be thankful.
    May 2003
    Peterborough, England
    Bad news http://www.videohelp.com/dvdhacks?dvdplayer=lg+lv837&hits=50&Search=Search
    A hack would only work with the DVD player side of things anyway, not the VHS. As a US spec machine you player will only play NTSC recorded tapes. Europe uses PAL so you will need a different, dual-standard machine to play them on.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Not going to happen.
    Your VHS tapes you received are PAL format....Canada uses NTSC format.
    You cannot "hack" a VCR.
