I have a matroska file that I want to re-encode to Mp4 H.264 AVC level 3 (so that my Kiss 1600 will play it hopefully).
I installed FFmpegx v0.0.9y but then after hitting the encode button it finishes almost immediately.
Any help?
source: Matroska h264, yuv420p, 1280x720
ac3, 48000 hz 5.1
target:
mp4 H.264 x264 h264 1280x720 940kbps 0,08 fps no crop
aac 48000hz 128 kbps
This is the process information:
Encoding started on Sun Feb 10 15:28:03 CET 2008
x264 [info]: using cpu capabilities Altivec
mp4 [info]: initial delay 0 (scale 30000)
movtoy4m
Copyright 2002-2006 Johan Lindstr??m
All rights reserved..
## Component Manager: attempting to find symbols in a component alias of type (imdc/IV32/intl)
2008-02-10 15:28:03.647 movtoy4m[1453] CFLog (21): Error loading /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType (No such file or directory, errno = 2)
2008-02-10 15:28:03.690 movtoy4m[1453] CFLog (21): Error loading /Library/Application Support/DivXNetworks/liblame3.92.dylib: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /Library/Application Support/DivXNetworks/liblame3.92.dylib (No such file or directory, errno = 2)
2008-02-10 15:28:03.695 movtoy4m[1453] CFLog (21): Error loading /Library/Application Support/DivXNetworks/liblame3.92.dylib: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /Library/Application Support/DivXNetworks/liblame3.92.dylib (No such file or directory, errno = 2)
2008-02-10 15:28:03.709 movtoy4m[1453] CFLog (21): Error loading /Library/Frameworks/Motion.framework/Versions/A/Motion: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /Library/Frameworks/Motion.framework/Versions/A/Motion (No such file or directory, errno = 2)
2008-02-10 15:28:03.720 movtoy4m[1453] CFLog (21): Error loading /Library/Frameworks/Motion.framework/Versions/A/Motion: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /Library/Frameworks/Motion.framework/Versions/A/Motion (No such file or directory, errno = 2)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP42/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP43/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MP4S/MSFT)
## Component Manager: attempting to find symbols in a component alias of type (imdc/MPG4/MSFT)
2008-02-10 15:28:03.778 movtoy4m[1453] CFLog (21): Error loading /Library/Application Support/DivXNetworks/liblame3.92.dylib: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /Library/Application Support/DivXNetworks/liblame3.92.dylib (No such file or directory, errno = 2)
2008-02-10 15:28:03.796 movtoy4m[1453] CFLog (21): Error loading /Library/Application Support/DivXNetworks/liblame3.92.dylib: error code 0, error number 2 (dyld: /Applications/ffmpegX.app//Contents/Resources/movtoy4m can't open library: /Library/Application Support/DivXNetworks/liblame3.92.dylib (No such file or directory, errno = 2)
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
## Component Manager: attempting to find symbols in a component alias of type (sdec/MM11/FhG )
## Component Manager: attempting to find symbols in a component alias of type (sdec/MM12/FhG )
## Component Manager: attempting to find symbols in a component alias of type (sdec/MM13/FhG )
## Component Manager: attempting to find symbols in a component alias of type (sdec/MSC9/FhG )
ERROR: Could not open movie: /Users/user/Movies/Lost/lost.s04e01.720p.hdtv.x264-ctu.mp4
x264 [info]: final ratefactor: 56.93
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]Could not find codec parameters (Video: h264, 1280x720)
/Users/user/Movies/Lost/lost.s04e01.720p.hdtv.x264-ctu.mp4.ff.video.mp4: could not find codec parameters
For 1280x720, you need at least AVC Level 3.1. Level 3.0 doesn't support that resolution.Originally Posted by flash74
Framerate issue (0.08 fps): the target framerate should be NTSC Film (23.976 fps), NTSC (29.97 fps) or PAL (25 fps). I would go with NTSC Film, as 720p usually is NTSC Film. 0.08 fps is one frame per 12.5 seconds! I guess the automatic framerate detection didn't work for this MKV.Originally Posted by flash74
Weird that it tries to access LiveType...Originally Posted by flash74
Weird that it tries to access DivX's Lame MP3 library...Originally Posted by flash74
If you had Decode with QuickTime activated, try it without.
If you had Decode with QuickTime de-activated, try it activated, but be sure to have Perian installed for QuickTime's MKV support.
Change avc level and reference frame
By cote112 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 10:45 -
Autoguessing of AVC level
By tom.tlr in forum Video ConversionReplies: 1Last Post: 14th Dec 2010, 13:25 -
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 3Last Post: 26th Dec 2009, 20:18 -
How can I remove a subtitle from a Matroska .avi file?
By HartsVideo in forum SubtitleReplies: 8Last Post: 2nd Sep 2009, 23:15 -
Choppy video with h.264 encoding from Matroska
By gabbahh in forum ffmpegX general discussionReplies: 2Last Post: 2nd Jul 2009, 21:05
Statistics
Newest guides
Latest tool updates
New media comments
