VideoHelp.com Forum
    I followed the 3 step manual and have searched the subject here in the forum.
    When encoding i get the following response from FFMPEG:
    /bin/sh: /Applications/_dvd/ffmpegX.app//Contents/Resources/flvtool2: /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/bin/ruby: bad interpreter: No such file or directory
    The directory doen't exist indeed. I've restarted and installed under original Admin account, but no luck.
    any sugestions?
  2. Explorer Case's Avatar
    FLVtool2 may be correctly installed. The error states that script interpreter 'ruby' isn't at the location where ffmpegX says it is. This seems to be a bug, as the wrong path is given. If you don't mind opening the application package and a text editor, you can fix it:
    http://forum.videohelp.com/topic345126.html#1807644
    Not sure if it is 10.4.x or what, but it seems to happen to some users, not all.
    Thanks Case, it worked like a charm. For any searches that end up here, text-edit or Xcode also work fine.
    /Applications/ffmpegX.app//Contents/Resources/flvtool2
    points to:
    Change this to:
    /usr/bin/ruby
    (right click ffmpegX.app and "show Package contents" to browse within)
  4. Member LoveyK's Avatar
    Ahh! I can't even get my terminal to recognize the FLVTool2 folder no matter where I move it, name it, hide it, Ahh! Ahh! Ahh!
    Last login: Sun Feb 10 17:44:00 on ttyp1
    Welcome to Darwin!
    cpe-24-243-49-171:~ Me$ cg/Users/Me/Desktop/FLVTool2-1.0.6/
    -bash: cg/Users/Me/Desktop/FLVTool2-1.0.6/: No such file or directory
    Ahhhh!
  5. Explorer Case's Avatar
    Try
    cd (for change directory),
    followed by a space character (to separate the command from the parameters),
    followed by /Users/Me/Desktop/FLVTool2-1.0.6/ (i.e. drag-and-drop the folder),
    followed by <enter>
  6. Member LoveyK's Avatar
    Thank you Case!
    The cg was a typo in the paste - but I was able to install the FLVTool2 per your instructions (gee! a simple space character!), I edited the path in BBEdit, and Voila! The Metadata works perfectly!
    Thanks again!
  1. what to do when a relatively new dvd recorder doesn't function correctly?
    By xtube in forum Newbie / General discussions
    Last Post: 17th Aug 2010, 04:02
  2. How To Install A Graphic Card Correctly?
    By themaster1 in forum Computer
    Last Post: 21st Jan 2010, 23:22
  3. Can't Install FLVTool2
    By visioner in forum ffmpegX bugs and suggestions
    Last Post: 25th Apr 2009, 06:53
  4. Panasonic DMRES45V DVD remote doesn't work correctly
    By cep8719 in forum Newbie / General discussions
    Last Post: 27th May 2008, 11:00
  5. Replies: 1
    Last Post: 26th May 2007, 07:33
