VideoHelp.com Forum
    Not enough room to really say what I mean.
    I encoded a movie to XviD through VDubMOD.Video looks great but audio is not so great.I went with 128 mp3 but it sounds like I used lower bitrate.
    What I want to know is how to add my AC3 audio to the video replacing the crummy mp3 and with minimal encoding.Otherwise I would just re-encode whole movie over.....but that takes ages on my PC so trying to avoid long processing.
    TIA
    Open your original file with VirtualDubMod. Export the AC3 track by selecting Streams -> Stream List and pressing Demux.
    Open the file you've already converted. Go to Streams -> Steam List. Hilite the MP3 track and press Disable. Press Add and select the AC3 track from above. Back at the main window select Video -> Direct Stream Copy. Then File -> Save as... In a minute you'll have a new file with the Xvid video and the original AC3 audio.
    Thank you !
    Very painless!
  1. Add audio won't work in audio menu.
    By petwes in forum Audio
    Last Post: 21st Jan 2012, 07:59
  2. Good software to add/ sync audio tracks?
    By jiopi in forum Editing
    Last Post: 14th Feb 2011, 07:25
  3. Help... tired of listening to encoded audio
    By pixeltweek in forum Audio
    Last Post: 18th Aug 2010, 03:31
  4. RipBot audio can't be encoded??
    By crankharder in forum Blu-ray Ripping
    Last Post: 13th May 2010, 14:56
  5. Command Line Tool that will output Re-Encoded Audio
    By Maikeru-sama in forum Video Conversion
    Last Post: 13th Jan 2008, 00:56
