VideoHelp.com Forum
    Hi!
    I have a Panasonic DMR-E55EB-S, which I think is a UK Version, and I've taken it with me to Central Europe.
    Now here the city cable TV runs through standard TV aerial cable -- with all the channel frequencies sent through it -- there is no cable Set Top Box. The problem I have is the Recorder won't pick up the stations. I'm guessing the tunner doesn't support VHF? VHF-3? It only picks up a few UHF stations but no sound, just crackle. The Auto Tune doesn't give any frequency selection it's just all automatic.
    As there is no STB to use Scart AV Input to pick up the stations; is there another way to get these stations through my recorder so I can record?
    Any help appreciated!!
    Thanks.
    Slovenia is PAL, so the signal type is not the problem if your unit is UK version? It's going to DVB-T in 2012, so maybe there's a digital signal already in prep for that???
    Yes it's PAL -- but the tunner isn't for digital of course. If I'm not mistaken the "free" non-digital stations in UK are in UHF -- but I need VHF, etc. So I'm stuck how to get the recorder to see these stations if the signal ONLY comes through "old" aerial cable.
  4. Member Krispy Kritter's Avatar
    As the recorder doesn't have the correct internal tuner, you have two options. Replace it with a model that does, or get an external tuner (even a old VCR with the proper tuner will work). The major drawback to the external tuner, is you will have to record on one of the Line-In inputs and all channel changing will need to be performed manually on the external tuner hardware which limits your programming recordings options.
    Google is your Friend
    Thanks for reply Krispy.
    Panasonic told me this too:
    Please be aware that a DVD recorder purchased in the UK would not be fully operable abroad due to the differing broadcast systems between the countries. The tuner is for British signals only.
    Grrrrrrr... I was thinking of hooking up a VCR, but hoped there was a better way to do it.
    Thanks again.
  1. Digital tuning on Panasonic DMR-EZ48V
    By knahs in forum Newbie / General discussions
    Last Post: 16th Mar 2012, 14:27
  2. best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
    By overheat in forum Newbie / General discussions
    Last Post: 28th May 2009, 20:57
  3. Panasonic DMR-EZ27 has lost its digital tuning capability
    By Frank-0-Video in forum DVD & Blu-ray Recorders
    Last Post: 23rd Feb 2009, 17:26
  4. Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
    By Surfmaster in forum DVD & Blu-ray Recorders
    Last Post: 20th Oct 2008, 20:45
  5. Panasonic dmr es-15
    By jean1938 in forum DVD & Blu-ray Players
    Last Post: 18th Jun 2008, 03:31
