hi
i use total commander
if i select mp3 songs in folder (insert-make them red) i would like to setup so my WMP (windows media player or other player) will play those selected mp3 files after pressing enter on keyboard...is that possible to setup somehow?
thanks so much for help
nobody??![]()
I seem to recall a similar question a few months back. I don't recall the solution or if there was a solution. You could try searching the forum or you may have better luck seeking an answer from Total Commander. Most tools have dedicated forums and tech support (or even an online FAQ).
Google is your Friend
how to setup wmp11 to remove mp3 songs that had been played from playlist
By deejay.2001 in forum ComputerReplies: 3Last Post: 19th Feb 2010, 11:24 -
total commander dont see folder with *stores your local website* sign
By deejay.2001 in forum ComputerReplies: 0Last Post: 12th Feb 2009, 05:32 -
iPod last.fm-type statistics program (total songs played in last week, etc)
By Salva Veritate in forum Portable VideoReplies: 0Last Post: 22nd Jan 2009, 15:54 -
Want to play mp3 songs in my car's cd player-what software converts it?
By jbitakis in forum AudioReplies: 5Last Post: 10th Jan 2009, 08:59 -
how to play more mp3 songs in total commander with 1 click (WMP)
By deejay.2001 in forum ComputerReplies: 1Last Post: 1st Nov 2007, 10:04
Statistics
Newest guides
Latest tool updates
New media comments
